• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
creating temporary swatch
Engaged ,
Apr 28, 2017 Apr 28, 2017
Hello.
Refering to my post thread #2305722 I stil have a question.
After creating an array that contains color-parameters like color values and color names I want the user to l´select one of those colours via dropbox-dialog.
The selected color should be inserted directly in a colorgroup of the document. First check if the group exists, check if color allready exists.
My problem is, that the parser won´t do that because (I verified it) the color which was taken out from the array is not a color but an object! And one can´t put an object into a colorgroup obviously... How an object becomes a "real" color without adding it to the swatches before? I mean something like a "temporary color".
function createColour() {
   var n=0;
    start: while(true) {
    app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
    var colorName =[];
    for (i=0; i < colourArray.length; i++) {
    colorName.push(colourArray.name + "\r");
    //Dialogbox mit Farbauswahl erstellen
    var dlg = app.dialogs.add();
    dlg.name = "SF_Kapitelfarben für Tabellen";
    var dlgCol = dlg.dialogColumns.add();
    var sText = dlgCol.staticTexts.add();
    sText.staticLabel = "Bitte wählen Sie eine Farbe aus:";
    var dropDown = dlgCol.dropdowns.add();
    dropDown.stringList = colorName;
    var res = dlg.show();
    n++;
    if (res == false)
    continue start;
        myTempNewColour = colourArray[dropDown.selectedIndex];
    myNewColorKey = dropDown.selectedIndex;
    break;
return myTempNewColour;
return myNewColorKey;
    dlg.destroy();
// ++++++++++ Funktion createColour() ENDE ++++++++++
function newColour() {
    // Prüfen, ob die Farbgruppe existiert
    var myTabColorGroup = myDoc.colorGroups.itemByName("SF_TAB_Farben");
    if(!myTabColorGroup.isValid){
        //alert("Farbgruppe ist nicht vorhanden");
        var myTabColorGroup = myDoc.colorGroups.add({name:"SF_TAB_Farben"});
        alert(myColours.name);
        exit();
    if(myTabColorGroup.isValid){
        //alert("Farbgruppe ist vorhanden");
            var myColorToCheck = myColours.itemByName(colourArray[myNewColorKey].name);
            // Wenn die Farbe nicht vorhanden ist ...
            if(!myColorToCheck.isValid){
               //Erstellt ein neues Farbfeld anhand der Eingabe und der vordefinierten Farben im colourArray
                tabellenFarbe = myColours.add(colourArray[myNewColorKey]);;
                myTabColorGroup.colorGroupSwatches.add({swatchItemRef:tabellenFarbe});
            // Wenn die Farbe (Eingabe) vorhanden ist ...
            if(myColorToCheck.isValid){
                //Holt sich die gewünschte Farbe aus den Dokumentenfarbpalette, anhand der Eingabe und der vordefinierten Farben im colourArray
                tabellenFarbe = myColours.itemByName(colourArray[myNewColorKey].name);
                 //alert("Farbe ist bereits in der Farbpalette vorhanden: " + tabellenFarbe.name);
                //alert("Die neue Farbe aus Ihrer Eingabe wurde hinzugefügt: " + colourArray[myNewColour].name);
            // Einfärben :
            // 1. von jeder unterkante einer jeden Zelle
            myTable.cells.everyItem().bottomEdgeStrokeColor = tabellenFarbe;
            // 2. von jeder Oberkante einer jeden Zelle
            myTable.cells.everyItem().topEdgeStrokeColor  = tabellenFarbe;
            // 3. aller Zeichen in der erste Zeile
            myTable.rows.firstItem().cells.everyItem().characters.everyItem().fillColor = tabellenFarbe;
I hope my explanation of the problem is clear enough
TOPICS
Scripting
Views
256
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Apr 29, 2017 Apr 29, 2017
LATEST
Okay, after some time I have now come to my own solution.
    var tabellenFarbe;
            switch(myColorToCheck.isValid){
                case false:
               //Erstellt ein neues Farbfeld anhand der Eingabe und der vordefinierten Farben im colourArray...
               //... und fügt sie in die Farbgruppe ein
                break;
                case true:
               //Verschiebt die Farbe in die Farbgruppe
                break;
            // Einfärben :
            myTable.cells.everyItem ().topEdgeStrokeColor  = tabellenFarbe;
// ++++++++++ newColour() ENDE ++++++++++
These are the changes:
In line 04 I created the variable.
Up to line 15 I used switch- instead if-condition
in line 28 I moved the color to the colorgroup
Votes
Translate
Translate
Report
Report
