The setup:
Result:
Tested JPEG 2000 (file extension .jpf) = SAME ISSUE (i.e. a JPEG instead of a JPEG 2000, labeled with a .jpf file extension)
Tested TIFF file (file extension .tif) = SAME ISSUE (i.e. a JPEG instead of a TIFF, labeled with a .tif file extension)
I had this issue a few years ago. Contacted customer support after attempting multiple methods to correct it. In the end, they had to remote access my computer, manually scrub ALL references to Acrobat from my system (lots of hidden files that a simple uninstall didn't remove) and initiate a clean installation.
Now, this issue it is back again. Naturally, It happens only when I need it to work as designed. Adobe may as well remove the other options if the only thing that Acrobat is going to support in the image export is a JPEG.
Has anyone else encountered this annoyance?
As per the description of the issue mentioned above, when trying to Export PDF form as image, it exports as jpeg instead of png, is that correct?
Check if there is an update available for Acrobat- launch Acrobat>click Help>Check for Updates
You may also visit these link to download updates manually:
Adobe - Acrobat : For Macintosh
If that doesn't work, try resetting preferences for Acrobat.
How to reset Preference settings in Acrobat.
What is the version of Acrobat installed on the machine?
Identify the product and its version for Acrobat and Reader DC
Which Operating System is installed on the machine?
Keep us posted with the results.
Shivam
Hello Adorobat, thank you for the response.
As the initial post stated, the file format on the image export is incorrect when exporting to anything other than a JPEG. The file exported will be labeled whatever file type was selected on export, but the actual format exported is JPEG. This happens regardless of the file type selected. PNG, TIFF, JPEG 2000. Only the JPEG export works as intended, because it is exporting a JPEG regardless of what is selected.
So, If I select JPEG, I get a JPEG labeled as a JPEG (ex: image.jpg). However, if I select a PNG, I get a JPEG file that is labeled as a PNG (ex: image.png). During the export, the popup window that briefly appears indicates it is exporting a JPEG (not the PNG selected). This supposed PNG file fails to open in Photoshop (because it is a JPEG). If I change the file extension to .jpg so that the extension matches the actual file format, the file opens.
I am using Creative Cloud for Teams. The account is up to date. The version is up to date according to the Creative Cloud app.
The Acrobat Pro DC version number is "2017 Release (Continuous) | Version 2017.009.20044"
Windows 10 Pro
Resetting the preferences using the instructions provided at the link did nothing to resolve the issue.
Thanks for providing the information.
Could you please try repairing Acrobat and see if that resolves the issue?
Click "Repair Installation" under Help menu.
-Shivam
Unfortunately, this also failed to resolve the issue.
I have tested the issue with a laptop computer and have encountered the same issue. So, it is apparently not isolated to just the desktop machine.
You may try running Cleaner tool which can be found here (for Windows) : Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs.
Reboot the machine.
Reinstall Acrobat DC and see if that resolves the issue.
Shivam
Thanks for the feedback Adorobat/Shivam. Please see my prior posts.
1) the last time this happened, I tried using one of the cleaner tools, and that wasn't enough to restore functionality.
2) this is not isolated to one computer. It is happening on two different machines.
Try exporting pdf using following link in a web browser with the same email address you are logged in with on the desktop and see if that works:
https://cloud.acrobat.com/exportpdf
Let us know how it goes.
Shivam
The web service produced a PNG file from a sample PDF generated from a Word Document, though the process is somewhat convoluted.
I attempted to use Acrobat Pro DC on the same PDF file with the same issue as noted in my original post: (Acrobat exported a JPEG file mis-labeled as a PNG instead of the desired PNG file.)
Hi Michael,
Thanks for trying the steps. Would it be possible if you can share the link for the pdf file with us?
(1) Please visit this link: https://cloud.acrobat.com/send
(2) Click + Add files > choose files from my computer
(3) Select the file > create link. You can copy paste the link here in the forums.
Shivam
I have uploaded a ZIP archive to the cloud service here.
The ZIP contains 4 files.
I was not able to save to pgn or jpeg tech support changed limitation to no limit in settings when exporting that solved my issue
Hi Michael,
Thanks for sharing the files. I have sent you a private message, please check the inbox for the same.
-Shivam
