Is anyone having trouble selecting text in a sticky note and copy and pasting it out?
If your sticky notes are locked, this can also cause the problem. Try opening them in the comments pane instead. Document Geek: How to Extract Text From Locked Comments within an Acrobat Shared Review
Hi Neill-fox,
As per the description above, you are facing the issue in copy and paste text in Comment, Is that correct?
Please check for any pending updates of Acrobat or Reader installed from Help>Check for updates.
You can also repair the installation files of Acrobat or Reader installed from Help>Repair Installation.
If the issue still persists, then please share the following details:
Hope this helps, and keep us posted with the results.
Regards,
Anand Sri.
