• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Windows 7 + FireFox 57 + Adobe Flash 27 NPAPI
New Here ,
Nov 15, 2017 Nov 15, 2017
[moderator: edited OS version in title, per comment #2]
We're trying to install the Adobe Flash ActiveX + Adobe Flash Plugin via SCCM.
After deploying the package, I can see Flash Active X is installing fine, but the plugin installation is not showing up.
The installation in both cases points to a MST transformation file - which is noted in the installation path of the Task Sequence Package.
I'm wondering if Adobe Flash flags are differentiated in version 27. We haven't packaged this software since version 16, and I understand their may be differences in the way it's done now.
Marcus
Views
5.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Microsoft embeds Flash Player ActiveX in Windows 10, as such, the Flash Player ActiveX installer will not run on Windows 10 - it'll fail with an error. Since it's embedded in the browser, updates are distributed by Microsoft via Windows Updates.
What exactly does this mean?  Where is it not showing up?  Control Panel? browser?
Are you adding an MST file to the MSI installer?
I'm not sure what you mean by "Adobe Flash flags"
Please provide the following installation log files, for the same installation attempt:
FlashInstall log file(s) saved at the following location:
  • 32-bit OS: C:\Windows\System32\Macromed\Flash\FlashInstal64.log
  • 64-bit OS: C:\Windows\System32\Macromed\Flash\FlashInstall32.log AND C:\Windows\SysWOW64\Macromed\Flash\FlashInstall32.log (both files are required)
  • verbose MSI installation log file with v+x (verbose + extra debugging) options enabled
Upload all files to cloud.acrobat.com/send (using the instructions at How to share a document), or to some other file sharing service of your choice that doesn't require login access.  Post the link to the uploaded files in your reply.
Votes
Translate
Translate
Report
Report
New Here ,
I'm so sorry - I was multitasking, and miswrote the initial issue. This is on a Windows 7 Machine. Do you want me to create another ticket in regards to this?
In regards to the flags: I'm using Microsoft's Orca to create an MST file to modify the Automatic updaters function of Adobe Flash.
http://www.itninja.com/software/adobe/flash-player-3/13-236
Votes
Translate
Translate
Report
Report
New Here ,
The key being "-au 2" being added to the target column, of the "CustomeAction" table.
The Robot Archive: SCCM - Package Adobe Flash Player in SCCM with ORCA
au 0=always install updates; au 1=notify me; au 2=never update.
IT Pro Tips for Adobe Flash Player 11 | ITNinja
Votes
Translate
Translate
Report
Report
Adobe Employee ,
no need to create a new discussion topic.  I edited the OS version in the title.
If the intent is to disable Auto Updates, the recommended deployment process is to deploy a custom mms.cfg file, immediately after running the installer, to disable the updates.  We don't recommend modifying the MSI installer with MST transform files.  To disable auto-updates (notification and background) add the following to the mms.cfg file:
AutoUpdateDisable=1
SilentAutoUpdateEnable=0
On 32-bit OS, the file is deployed to C:\Windows\System32\Macromed\Flash.  On 64-bit OS, the file is deployed to C:\Windows\SysWOW64\Macromed\Flash.
A note on this is included in the Admin Guide, section 3.2.  I thought i was also included in the SCCM section, but I don't see it there.  I'll submit those updates for the next version of the Admin Guide.
Votes
Translate
Translate
Report
Report
New Here ,
I don't see anything about "mms.cfg" files being mentioned in the 3.2 section of the manual. I do see it being mentioned in Chapter 4 though?
Appreciate all of the information.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
yeah, we need to document it better. The next update will be with the version 28 release.
Please do provide the previously requested information so that we can investigate further.
Thank you.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 17, 2017 Nov 17, 2017
Out of the office till the week after next. Will respond then.
Thanks again.
-Marcus
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
sounds good.  thank you.
Votes
Translate
Translate
Report
Report
New Here ,
The MSI Packages I'm refering to:
"install_flashplayer_27_active_x.msi
"install_flash_player_27_plugin.msi"
Downloaded from
Adobe Flash Player Distribution | Adobe
Votes
Translate
Translate
Report
Report
