• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Issuing installing Flash update 30.0.0.113
New Here ,
Jun 11, 2018 Jun 11, 2018
I am trying to install the Flash NPAPI 30.0.0.113 update offline on 4 systems. 1 installed with no error. The others are all giving an error: 'C:\Windows\system32\Macromed\Flash\FlashUtil64_30_0_0_113_Plugin.exe is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status )xc0000022.'
I've tried a new copy of the update, uninstalling/reinstalling, repairing Visual C++ 2013 Redistributable, all with no avail. Any suggestions?
Views
910
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
We'll need to get some information from you to troubleshoot further.  Please provide the following:
  1. Operating system, including version, of the system that Flash Player installed on without errors
  2. Operating system, including version, of all three (3) systems that return the error.
  3. Exact file name of the installer file you are using to install Flash Player.
  4. FlashInstall log files from all of the systems that are failing.  Since this is a 64-bit OS, there are 2 files:
    1. FlashInstall32.log saved at C:\Windows\SysWOW64\Macromed\Flash
    2. FlashInstall64.log saved at C:\Windows\System32\Macromed\Flash
  5. Screenshot of the permissions on the FlashUtil64_30_0_0_113_plugin.exe file on all 3 systems.  To obtain the permissions, do the following:
    1. Right-click on the  FlashUtil64_30_0_0_113_plugin.exe file and select Properties
    2. In the Properties window, go to the Security tab
    3. In the Security tab, select your account
    4. Take a screenshot of the account permissions
Please name the files in such a manner that the screenshots and log files match up.  For example: System1_permissions.png, System1_FlashInstall32.log, System1_FlashInstall64.log, etc
Upload all files to cloud.acrobat.com/send using the instructions at How to share a file using Adobe Document Cloud  or some other file sharing service of your choice that doesn't require user account login to access.
Post the link to the uploaded files in your reply.
Thank you.
Maria
Votes
Translate
Translate
Report
Report
New Here ,
Jun 12, 2018 Jun 12, 2018
I'm no longer sure that the one system which did not show the error installed correctly either, as the plugin does not show up in FireFox.
For what it's worth, it looks like the install proceeds successfully (progress bar goes to 100%). I believe the error (occurs twice) comes when the plugin is launched.
The installer is: install_flash_player.exe
We change the wording to differentiate it from other flash installers to: install_flash_player_npapi.exe
The systems are all Server 2012 R2
The files are at:
Shared Files - Acrobat.com
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
Do you mean it's not showing up in about:plugins, or something else?
Flash Player is not supported on any Server versions (see Tech specs | Adobe Flash Player for supported platforms), which means we do not code for, nor test on, any Server version, and we don't invest much time troubleshooting issues on non-supported platforms, unless they're also reported on supported platforms, and thus far, I've not seen this issue reported on supported platforms.
With that said, we'll investigate a bit further.  Can you provide the following:
  • What is the permissions on the C:\Windows\SysWOW64\Macromed\Flash\mms.cfg file?
  • When does the error "FlashUtil64_30_0_0_113_Plugin.exe is either not designed to run on Windows..." appear
  • Please provide a screenshots
    • of the error message.
    • the 32-bit and 64-bit Flash directories after running the 30.0.0.113 installer that returns the error
  • Run the uninstaller, and run the 29.0.0.171 NPAPI installer to verify that the same issue is not reproducible in 29.0.0.171.
Votes
Translate
Translate
Report
Report
