Hello,
I have had CS5.5 Design Premium (Windows) since 2011. it has been working fine until two weeks ago when Adobe Illustrator stopped saving .AI files. It would just freeze and close.
On the advice of Adobe Customer Care, I followed the steps outlined here: Troubleshoot Windows system errors, freezes | Adobe software
Nothing helped, but after reinstalling I got the following error message:
Exit Code: 6
------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 5 error(s), 55 warning(s)
WARNING: DW066: OS requirements not met for {0D96CFE6-376D-44B8-808A-16F3BEB73263}
WARNING: DW066: OS requirements not met for {7202D4A7-F7E6-4e7a-B77D-7B1C4E8B5CA6}
ets
----------- Payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 2.0.0.0 -----------
WARNING: DF029: ARKServiceControl::StartService: Service not started/stopped SwitchBoard. Current State: 0 Exit Code: 0 Service Specific Exit Code: 0(Seq 1)
----------- Payload: {2EE4F060-CEE6-4002-AA8B-91B791541767} Pixel Bender Toolkit 2.6.0.0 -----------
WARNING: DF035: CreateAlias:Icon file does not exist at C:\Program Files (x86)\Adobe\Adobe Utilities - CS5.5\Pixel Bender Toolkit 2.6\windows\pb_app.icofile:\\\C:\PIXELB~1\source\winwood\Staging 0X1.FE4B88P-1005rea\windows\pb_app.ico42178f80493091e8e552c84a2897e9da68fce32_32_f80493091e8e552c84a2897e9da68fce for icon C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Design Premium CS5.5\Adobe Pixel Bender Toolkit 2.6.lnk with target C:\Program Files (x86)\Adobe\Adobe Utilities - CS5.5\Pixel Bender Toolkit 2.6\Pixel Bender Toolkit.exe(Seq 89)
----------- Payload: {7202D4A7-F7E6-4e7a-B77D-7B1C4E8B5CA6} Adobe Flash Player 10 ActiveX 10.0.0.0 -----------
ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Hasmita\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Hasmita\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
----------- Payload: {8DADF070-FE60-4899-8EF0-4242E7702F7D} Adobe Fireworks CS5.1 11.1.0.0 -----------
WARNING: DF012: File/Folder does not exist at D:\Adobe CS5_5\payloads\AdobeFireworks11.1.0All\OEM(Seq 1215)
----------- Payload: {5BDE0A1B-35BF-4224-A54F-73786EECDFC1} Adobe Fireworks CS5.1_AdobeFireworks11.1.0en_GBLanguagePack 11.1.0.0 -----------
WARNING: DF012: File/Folder does not exist at D:\Adobe CS5_5\payloads\AdobeFireworks11.1.0en_GBLanguagePack\OEM(Seq 74)
----------- Payload: {D97AF04B-B70A-4862-BC25-31E6D9C4A529} Adobe Flash CS5.5 11.5.0.0 -----------
ERROR: DR012: Setting Registry Value Failed. Error 5 Access is denied.(Seq 154)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Flash Player 10 ActiveX: Install failed
I am not that tech savvy so I have no idea what the error codes mean, so I decided to see if there were any problems with Photoshop or Illustrator (the main ones I use). Oddly, Illustrator now save .AI files, BUT the text function in both do not work. Adobe Photoshop the following message appears:
'Could not complete your request because something prevented the text engine from being initialized'
That's the only problem I have noticed.
Thanks for reading, I hope someone can help me figure this out!
Two ideas that MAY work to install and/or run old programs in Windows 10
-RIGHT click the program icon or EXE and select a compatibility mode in the pop up option window
-or Run as Administrator http://forums.adobe.com/thread/969395 to assign FULL Windows permissions may help... this says Encore, but is sometimes required for ALL Adobe programs (this is NOT the same as using an Administrator account) so follow the instructions for your specific program
Also... every time Microsoft issues a Win10 update, there is the risk that an old program that HAS been working after the initial Win10 upgrade will STOP working... bottom line, old programs require a matching old operating system
