Hey Guys,
I have a built Windows 10 Computer with a 6-core i7 processor and a 4GB NVidia graphics card. I am a feature film sound editor. I'm trying to divide my mix into sub mixes for Dialogue and M+E tracks with the reels imported from Premiere Pro. The shoot was with RED Footage and Proxies.
Every time I choose a plug in from the dropdown menu in the Sub mix, Audition Crashes and it doesn't even submit a crash report or anything at that.
And I'm on deadline to get this done. I would try this in protools, but I'm short on time and I don't do a lot of sound designing in Pro Tools, though I should though.
Is there any way to bypass this and get Audition working properly or should I do something else?
Ah just figured it out - realized that the bus track I had added was not a 5.1 track - as soon as I corrected that it seems to work fine.
You can manually send a Crash Report to Adobe following the FAQ Audition Crashed. Now what?
However that won't help immediately with your present problem.
I am not quite sure that I follow your workflow that is causing your crash. Can you explain in a little more detail what you are doing to cause the crash? What sort of plugin are you selecting and from which menu? A screen grab of your Audition session posted here may help us diagnose the problem.
Hi triceptus,
Are all the plug-ins you are using updated to work with the version of Audition you are using? Can you check on that?
Kevin
I'm having the same problem with Audition crashing when I try to add a channel Mixer rack effect into a sub mix.
I'm using Audition build 11.1.13 on a windows 7 system.
The project is is a 5.1 surround project - working on a dynamic link from Premiere.. All of my submixes (DIAL, SFX etc.) are routed to an additional sub mix on which I want to put a channel mixer effect to get a stereo downmix. But as soon as I select the Channel mixer option from the amplitude and compression menu - Audition completely crashes. Everything else is working fine.
Gene
I
