I use this script quite often. It was enhanced yesterday by awesome people on here. I was wondering if it's possible, instead of it saving as a png to save as a psd file, but with the image size measurements still included? Many, many thanks in advance
var pth = "~/Desktop"; // path to save the file, the default save to the desktop, change as needed
var tmp = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.MM;
var w = Math.round(activeDocument.width.value);
var h = Math.round(activeDocument.height.value);
var file = new File(pth+ "/" + w+"x"+h + ".png");
save_as_png(file);
app.preferences.rulerUnits - tmp;
function save_as_png(file, filter, none, comp)
try {
if (filter == undefined) filter = "PNGFilterAdaptive";
if (none == undefined) none = true;
if (comp == undefined) comp = 9;
var d = new ActionDescriptor();
var d1 = new ActionDescriptor();
if (none)
d1.putEnumerated(stringIDToTypeID("PNGInterlaceType"), stringIDToTypeID("PNGInterlaceType"), stringIDToTypeID("PNGInterlaceNone"));
else
d1.putEnumerated(stringIDToTypeID("PNGInterlaceType"), stringIDToTypeID("PNGInterlaceType"), stringIDToTypeID("PNGInterlaceAdam7"));
d1.putEnumerated(stringIDToTypeID("PNGFilter"), stringIDToTypeID("PNGFilter"), stringIDToTypeID(filter));
d1.putInteger(stringIDToTypeID("compression"), comp);
d.putObject(stringIDToTypeID("as"), stringIDToTypeID("PNGFormat"), d1);
d.putPath(stringIDToTypeID("in"), file);
d.putBoolean(stringIDToTypeID("copy"), true);
executeAction(stringIDToTypeID("save"), d, DialogModes.NO);
catch (e) { alert(e); throw(e); }
This is what I came up with:
...//https://forums.adobe.com/thread/2558835
var saveFile = new File(pth + "/" + w + "x" + h + ".psd");
SavePSD(saveFile);
app.preferences.rulerUnits = tmp;
function SavePSD(saveFile){
psdSaveOptions = new Pho
Please, finally read the documentation.
Thanks so much for your time, I know you've been so patient and helpful to me. I really appreciate it.
I have tried changing the png to psd myself but I get a NaN result.
var file = new File(pth+ "/" + w+"x"+h + ".psd");
psdSaveOptions = new PhotoshopSaveOptions();
psdSaveOptions.embedColorProfile = true;
psdSaveOptions.alphaChannels = true;
psdSaveOptions.layers = true;
activeDocument.saveAs(saveFile, psdSaveOptions, true, Extension.LOWERCASE);
I can't figure out what I've done wrong 😕
What does NaN mean? )
You forgot to insert a line to call a function.
SavePSD(file)
And it works.
And there is a typo (it looks like mine)
must be
SavePSD(saveFile);
psdSaveOptions.annotations = true;
psdSaveOptions.spotColors = true;
P.S. I believe that the NaN result (not a number) in the JavaScript Console of ESTK was due to the erroneous - hyphen rather than equal = sign. Once I fixed that the original ruler units were returned (line 09).
Ah thank you so much! I really appreciate your hard work!
