I am experiencing so many strange things since I downloaded Photoshop 20.01, such as:
- Photoshop 'freezes' at least once a day, all activity is then impossible and I have to restart it.
- I can no longer scale unproportionally... even when I uncheck the link between height and width, it scales proportionally.
- Scaling proportionally USED to be while holding the Shift key. Now I have to hold the Caps Lock key. Not that that is a problem, once you know it.
- Several smaller things that I would need to think of but several things that I have experienced ever since I downloaded the new version.
I work on the newest Microsoft 10 and have a brand new computer.
Anyone else?
tinkelbel wrote
Hi Ajiija, how do you go back to an older version?
And I forgot: I often have an error that there is a problem with the display driver (gpu). Every time I see it I go in the Preferences and tell Photoshop that it needs to use the graphic professor (and I did update the driver when I had my new pc installed, just a couple of weeks ago).
Or drag a guide from the left ruler while an object has been selected in Transform mode (because I want to draw guides to mark the borders of that object). That was perfectly possible before this upgrade.
Agreed completely...the new version of Photoshop is tremendously slowed down...laggy with all tools slow...
I reverted to 2018 until Adobe addresses the issues...I have even considered cancelling the subscription and just buying Elements at this point...
For now, I continue with the 2018 version without the problems...
Hi
First thing to do is reset PS preferences
Adobe made some changes you can see the new features here
New and enhanced features | Latest release of Photoshop CC
You can revert how the transform works
Scroll down to this bit
How do I turn off the new proportional scaling by default behavior while transforming layers?
To add a new guide while in transform mode hold the shift key while dragging a guide
For the GPU issue take a look here
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
I would advice enabling this option in preferences as it's causing some people issues with it disabled
Can you post your Photoshop system info, in Photoshop go to Help > System Info and copy and paste that into this thread
Hi Ged, yes, the 'legacy compositing' was the first thing that I noticed... color overlay blend mode gave all kinds of strange colors, that was solved when I checked that.
Thanks for the other tips, will try these out and see how it goes. If not, I'll revert back to an older version.
No worries, personally I'm not having any issues with the latest version, it's always a good idea to keep an old version installed for situations like yours.
There will always be bugs in new versions, even the last update from 20.0.0 to 20.0.1 has caused issues with opening images from Lightroom to Photoshop when Photoshop isn't opened
I see that someone above explained how to install older versions so I won't repeat it...good luck...
I seem to have the new version working properly now...no lags, no problems...I had thought that I would have to just use 2018...but 2019 is now working...
I will explain what I did, but for the life of me, I don't know why it did...
I opened 2019...the same lagginess appeared...same problems described by others here...
I then went into preferences and selected "reset preferences on quit" under the General tab...
But, I did NOT quit at that point...
I went into Performance and checked the block for "legacy compositing"...
At that point, I closed Photoshop 2019 and rebooted the computer...
I then restarted 2019...and all was well..!!
Makes absolutely no sense because when I checked the settings again, the "legacy compositing" was now disabled (unchecked)...and the "reset preferences on quit" was no longer enabled either...
When it opened, of course, I was greeted with the usual first use multiple windowed Greeting screen...and I just set it up the way I like to see on my screen...
But it is flying again now...
I have no explanation for why this worked...but I'll pass it along for others...
Like I said, I don't know why that worked for me...but it did...
I hope others find the solution...
