I recently update my adobe acrobat. And i face a problem, when i search on my document it didn't give me search result screen sort as old version . for this i facing many problem even i don't fill comfortable with searching on document. Please add this feature as like as old version.
Hi Sukantos,
Sorry for the delay in response.
This is an as designed behavior. When you search text in the PDF, it will highlight the searched text.
Then you just need to press the arrow key provided at the top right of the screen to move towards and backward to the next highlighted text in the PDF.
The second screenshot that you have shared above, could you please confirm the application version used to have that time.
Please share your suggestion/feedback on this with the team over here Adobe Acrobat for Android - Feature Request/Bug Report Form
Hope the information helps.
Let us know if you have any questions or need any help.
Regards,
Meenakshi
Hi sukantos,
As per the issue description mentioned above, you are not getting search results when searching for text in pdf file in acrobat reader app, is that correct?
I tried replicating the issue with acrobat reader app version 18.5.1 but the issue was not reproducible. Make sure the pdf you are trying to search text is not a scanned pdf. Also, try replicating the issue with another pdf file and check if this behavior continues.
Let us know if you need any help.
Shivam
Yeah it give me search result but how many search result are there? and what are the page number is ? It doesn't show . but your old version gives all those result. even it gives a screenshot all those page, which have those result....
Hi sukantos,
Would it be possible to share the screenshot when searching pdf in the previous version and when searching in new version for better understanding of the issue? To share a screenshot here in the forums, refer to the steps given in this link:
https://forums.adobe.com/docs/DOC-7043#jive_content_id_How_do_I_attach_a_screenshot
You may also visit following likn to share your feedback:
Shivam
For new version the search result is
An old version like this
Can you see the difference?
Hi Sukantos,
Regards,
Meenakshi
