Hello,
several times I wanna install the Flash Player in Windows 7 64 bit for ie and failed. The instalation program says ''failed, Register problems''.
The couriosity is that I can install Flash Player for Mozilla Firefox without any Problems but not for IE. So I deinstall with the Adobe Routine but always the same result. The Flash Player for ie do not install.
Who can help me? Answers please in very simple english words (like you say it to a 6yo child)
ore in german.
thanks
Uwe
A "failed to register" error indicates permissions errors in the registry and/or file system. You're not seeing this when installing Flash Player for Firefox because Flash Player for Firefox and IE write to different locations of the registry. You'll need to fix permissions in the registry/file system in order to install Flash Player for IE. Please see the Microsoft tech note https://support.microsoft.com/en-us/kb/968003 for instructions on fixing the registry/file system permissions.
I have done these steps. But the problem is right there. I had install with web installer 'flashplayer23ax_raie_install.exe' and with downloaded installer 'install_flash_player_ax.exe'. Both times same result. The ActiveX-Steuerelement can not be registered.
Please provide the FlashInstall.log file saved at C:\Windows\SysWOW64\Macromed\Flash. You can upload the file to cloud.acrobat.com/send using the instructions at How to share a document and post the link to the uploaded file in your reply.
I think there's a misunderstanding. I'm requesting the log file, FlashInstall.log, saved at C:\Windows\SysWOW64\Macromed\Flash. Please do the following:
Maria
OK,
as I had told you before my english is not good.
So here again a link, hope this is right:
Dateien freigegeben - Acrobat.com
To say it again, in firefox I have installed the flashplayer and it works. Only in IE I can NOT install the flash player. If I use IE I see no video files on embetted you tube links. But I need IE as some old sites do not work corectly with firefox.
thanks for help.
Hello Maria,
get I an anser some day??? Nearly 2 month without any reaction from you! The problem still exist until today. Your new update also do not work with IE. Always registration foults.
would be great if some one give me an answer.
I sincerely apologize. I apparently missed your reply. I do see an ActiveX Control registration error in the log file. I suspect the error is still the same. Please see the FAQ How do I fix Windows permission problems with Flash Player? for information on fixing permissions issues.
Maria
As I had written on 15.Oktober.2015
I had done these stepps and the problem exist.
So I had done so another time and the problem exist I can NOT install flashplayer for IE. Register Error.
after that you wanna the log file to have a look.
So you have the log file.
And as I had told you before: This windows 7 instalation is made new, all windows updates are done.
But I can not install flash player in IE. On Mozilla Firefox it works. But some old internet sites need IE for corect seeing. So I need flash on IE.
How can I install without these Register Error???
No other program have these error !
Hope to get an answer.
