Locked
Error 1722 when trying to install Adobe Flash Player ActiveX MSI - Server 2012 R2
Jan 18, 2017 Jan 18, 2017
I'm trying to install Flash Player on a computer, but it fails again and again. This is not a problem with the new installer; previous ActiveX versions doesn't work either. I have tried both online and offline installer. NPAPI and PPAPI works fine.
The computer that fails is a virtual Windows Server 2012 R2 used for terminal services.
The offline installer gives the following error: "Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: ...\InstallAX_24_0_0_..."
The online installer gives the following error at approximately the same time during the installation phase: "Failed to register"
I have tried the Adobe uninstaller and all the manual steps beneath it: Uninstall Flash Player for Windows
I have tried msizap on all GUID's listed here, from most recent and back to 18.0.0.160: MSI GUID list for Flash Player​
I have tried to reset the registry permissions here (I am aware of the OS descrepency): Troubleshoot Flash Player install issues related to Windows registry permissions
I also manually removed the keys HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia and HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Macromedia (which only contained Flash entries) to no avail.
MSI log: https://justpaste.it/12j0h
C:\Windows\System32\Macromed\Flash\FlashInstall.log
=O====== M/24.0.0.194 2017-01-18+11-01-38.838 ========
0000 00000042
0001 00001113 C:\Users\username\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\* 3
0002 00000010 "C:\Windows\system32\Macromed\Temp\{E03840ED-7275-43AA-90B3-9051F5901072}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0003 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0005 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil64_24_0_0_194_ActiveX.exe/ 2
0006 00000013
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_24_0_0_194_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_24_0_0_194_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00001032 C:\Windows\system32\Macromed\Flash\Flash64_24_0_0_194.ocx 0
0011 00000018
0012 00001032 C:\Windows\system32\Macromed\Flash\Flash64_24_0_0_194.ocx 0
=X====== M/24.0.0.194 2017-01-18+11-01-40.687 ========
C:\Windows\SysWOW64\Macromed\Flash\FlashInstall.log
=O====== M/24.0.0.194 2017-01-18+11-01-36.267 ========
0000 00001113 C:\Users\username\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\* 3
0001 00000010 "C:\Users\USERN~1\AppData\Local\Temp\{22AF9D99-A980-4071-A0BD-1D0BB956B9EA}\InstallAX_24_0_0_194.exe" -install -msi -prev 24.0.0.194
0002 00001036 Software\Macromedia\FlashPlayerActiveX/UninstallerPath 2
0003 00001036 Software\Macromedia\FlashPlayer\SafeVersions/24.0 2
0004 00001036 Software\Macromedia\FlashPlayerActiveX/UninstallerPath 2
0005 00000011 1
0006 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash.ocx 5
0008 00000018
0009 00001045 C:\Windows\SysWOW64\Macromed\Flash\Flash.ocx 5
0010 00001015 C:\Windows\SysWOW64\Macromed\Flash\Flash.ocx 5
0011 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_24_0_0_194_ActiveX.exe/ 2
0012 00001015 C:\Windows\SysWOW64\Macromed\Flash\activex.vch 5
0013 00001045 C:\Windows\SysWOW64\Macromed\Flash\activex.vch 5
0014 00001015 C:\Windows\SysWOW64\Macromed\Flash\activex.vch 5
0015 00000013
0016 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_24_0_0_194_ActiveX.exe
0017 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_24_0_0_194_ActiveX.dll
0018 00000023 C:\Windows\SysWOW64\Macromed\Flash\activex.vch
0019 00001031 C:\Windows\SysWOW64\Macromed\Flash\activex.vch:5
=X====== M/24.0.0.194 2017-01-18+11-01-43.082 ========
[moderator: added 'MSI - Server 2012 R2' to title for clarity]
6.1K
Adobe Employee , Jan 18, 2017 Jan 18, 2017
As of Windows 8, and Server 2012, Microsoft embeds Flash Player in IE (and Edge in Win10) and all Flash Player for IE/Edge updates are released by Microsoft via Windows Update.  The ActiveX MSI installer should not run at all on Sever 2012.  This is a known bug and we are working on a fix.
Maria
Adobe Employee ,
Maria
Feb 13, 2018 Feb 13, 2018
hello,
if the ActiveX MSI installer  was installed because we didn't know in windows 2012R2 has it embedded, then we uninstalled it.
but the flash folder with .exe still exist under the macromed folder. can we safely deleted it?
Adobe Employee ,
What files remain in the Macromed folder?  Please post a screenshot of the Macromed folder in question.  To take and post a screenshot see https://forums.adobe.com/docs/DOC-7043#jive_content_id_How_do_I_attach_a_screenshot
Feb 14, 2018 Feb 14, 2018
Adobe Employee ,
Please don't post the same issue to multiple locations.  It results in forked conversation and related comments existing in one discussion topic, but not another, which results to confusion.  You already have a discussion topic on this issue at Re: the link for flash player with active X patch? and are being assisted there.   I'm locking this discussion topic.
Feb 15, 2017 Feb 15, 2017
Respectfully, " ...we are working on a fix." is NOT a solution. Has there been any update on this issue - any progress made - any suggestions for a temporary work around?
Adobe Employee ,
correct, "we are working on a fix" is not a solution, it's just that "we are working on a fix" as of the time my comment was posted.
I've been informed this bug is fixed in yesterday's release.  FP 24.0.0.221 ActiveX MSI will not run on Server 2012.
Mar 28, 2017 Mar 28, 2017
I'm still having this issue as of version 25.0.0.127.
Adobe Employee ,
What is 'this issue'?  Flash Player ActiveX Control installer is not supposed to run on Server 2012 since Microsoft embeds Flash Player ActiveX Control for IE in Server 2012.  The expected behaviour is that the installer will fail to run with the message:
Your Microsoft Internet Explorer browser includes the latest version of Flash Player built-in.  Windows Update will inform you wen new versions of the Flash Player are available.
If you are observing different behaviour please provide the following:
  • name of installer file being used
  • behaviour being observed
  • screenshot of the error, if any
