I'm working on a PDF document of 44 pages, edit from INDESIGN, which mix text & images.
My client send me back the PDF document with comments on bubbles.
I was editing the comments on bubbles, and once i reach the second half of the document, it keep crashing after i edit new comments (especially when i want to go to the next page, using the mouse's wheel).
How to fix that issue ? Is it a bug of the software ? Is there any fix ?
Thanks for your help !
here is a screenshot of the message, after crashing :
Hi Jossminte,
As per the description above, the Acrobat Pro DC is crashing when you try to edit any comment in a PDF, Is that correct?
Please check for any pending updates for Acrobat Pro DC from Help>Check for updates.
You may also try to repair the installation files of Acrobat Pro DC from Help>Repair Installation.
If this does not help, please check with any other PDF file.
Is it a Mac or Windows machine?
Check the dot version of Acrobat Pro DC installed, launch Acrobat>navigate to Help menu>select
...Copy link to clipboard
Hi Jossminte,
Check the dot version of Acrobat Pro DC installed, launch Acrobat>navigate to Help menu>select About Adobe Acrobat Pro DC.
You may refer to the following links: For Windows: Resolve Acrobat DC intermittent crashes on Windows
For Mac: Acrobat Pro keeps crashing every 8-10 seconds on Mac Lion (Installation & updates)
Keep us posted with the results.
Anand Sri.
I'm having the same problem as well. I try to edit a pdf for my job and no matter what action I'm taking (meaning that i could just be editing it or trying to get to a page i need to edit) and it crashes. Sometimes it crashes quicker and sometimes it takes a few more seconds, but I never have it open for more than 2 minutes before it crashes on me. I'm on Mac version 10.13. Here's the problem report:
Process: AdobeAcrobat [969]
Path: /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
Identifier: com.adobe.Acrobat.Pro
Version: 17.012.20098 (17.012.20098)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: AdobeAcrobat [969]
User ID: 501
Date/Time: 2017-10-09 07:41:47.127 -0500
OS Version: Mac OS X 10.13 (17A405)
Report Version: 12
Anonymous UUID: 69167E50-5752-9828-1A88-899FB7928393
Time Awake Since Boot: 2400 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000055242100
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0x55242100:
__TEXT 000000010327f000-0000000103280000 [ 4K] r-x/rwx SM=COW / [/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat]
Application Specific Information:
objc_msgSend() selector name: acroOSXFSGetPlatformPath:
Performing @selector(executeNSMenuItem:) from sender AVCocoaMenuItem 0x6040004b6a40
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x00007fff66e06ea9 objc_msgSend + 41
1 com.adobe.Acrobat.framework 0x00000001032a58cd 0x10328a000 + 112845
2 com.adobe.Acrobat.framework 0x00000001035861ef 0x10328a000 + 3129839
3 com.adobe.Acrobat.framework 0x00000001035a898f 0x10328a000 + 3271055
4 com.adobe.Acrobat.framework 0x00000001035a5865 0x10328a000 + 3258469
5 com.adobe.Acrobat.framework 0x00000001035a4d6f 0x10328a000 + 3255663
6 com.adobe.Acrobat.framework 0x0000000103551798 0x10328a000 + 2914200
7 com.adobe.Acrobat.framework 0x0000000103551585 0x10328a000 + 2913669
8 com.adobe.Acrobat.framework 0x00000001035a4646 0x10328a000 + 3253830
9 com.apple.AE 0x00007fff41563e20 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 1788
10 com.apple.AE 0x00007fff415636c7 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 41
11 com.apple.AE 0x00007fff415635b5 aeProcessAppleEvent + 383
12 com.apple.HIToolbox 0x00007fff3f7cef60 AEProcessAppleEvent + 55
13 com.apple.AppKit 0x00007fff3dabccb6 _DPSNextEvent + 2788
14 com.apple.AppKit 0x00007fff3e251d98 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
15 com.apple.AppKit 0x00007fff3dceefcb -[NSApplication _doModalLoop:peek:] + 476
16 com.apple.AppKit 0x00007fff3ded3c83 __35-[NSApplication runModalForWindow:]_block_invoke_2 + 64
17 com.apple.AppKit 0x00007fff3ded3c30 __35-[NSApplication runModalForWindow:]_block_invoke + 75
18 com.apple.AppKit 0x00007fff3e38106c _NSTryRunModal + 100
19 com.apple.AppKit 0x00007fff3dceca5d -[NSApplication runModalForWindow:] + 133
20 com.apple.AppKit 0x00007fff3dec1e93 __19-[NSAlert runModal]_block_invoke_2 + 158
21 com.apple.AppKit 0x00007fff3dec1de2 __19-[NSAlert runModal]_block_invoke + 75
22 com.apple.AppKit 0x00007fff3e38106c _NSTryRunModal + 100
23 com.apple.AppKit 0x00007fff3dd61659 -[NSAlert runModal] + 124
24 com.adobe.Acrobat.framework 0x000000010355b182 0x10328a000 + 2953602
25 com.adobe.Acrobat.framework 0x0000000103a149d9 0x10328a000 + 7907801
26 com.adobe.Acrobat.framework 0x0000000103a147ae 0x10328a000 + 7907246
27 com.adobe.Acrobat.framework 0x000000010355bf5c 0x10328a000 + 2957148
28 com.adobe.Acrobat.framework 0x0000000103a14f89 0x10328a000 + 7909257
29 com.adobe.Acrobat.framework 0x0000000103a1f37e 0x10328a000 + 7951230
30 com.adobe.Acrobat.framework 0x0000000103878a62 0x10328a000 + 6220386
31 com.adobe.Acrobat.framework 0x0000000103d8ce4f 0x10328a000 + 11546191
32 com.adobe.Acrobat.framework 0x00000001035668e1 0x10328a000 + 3000545
33 com.apple.AppKit 0x00007fff3e2539a6 -[NSApplication(NSResponder) sendAction:to:from:] + 312
34 com.apple.AppKit 0x00007fff3dce935f -[NSMenuItem _corePerformAction] + 323
35 com.apple.AppKit 0x00007fff3dce90e7 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114
36 com.apple.AppKit 0x00007fff3dd6ecba -[NSMenu performActionForItemAtIndex:] + 133
37 com.apple.AppKit 0x00007fff3dd6ec25 -[NSMenu _internalPerformActionForItemAtIndex:] + 94
38 com.apple.AppKit 0x00007fff3dd6ea55 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 106
39 com.apple.AppKit 0x00007fff3dc354c2 NSSLMMenuEventHandler + 882
40 com.apple.HIToolbox 0x00007fff3f798284 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1541
41 com.apple.HIToolbox 0x00007fff3f7975cd SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374
42 com.apple.HIToolbox 0x00007fff3f7ac8d1 SendEventToEventTarget + 39
43 com.apple.HIToolbox 0x00007fff3f7f5e09 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411
44 com.apple.HIToolbox 0x00007fff3f81ed3e SendMenuCommandWithContextAndModifiers + 49
45 com.apple.HIToolbox 0x00007fff3f81ecfa SendMenuItemSelectedEvent + 188
46 com.apple.HIToolbox 0x00007fff3f81ebd4 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
47 com.apple.HIToolbox 0x00007fff3f93721c PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1662
48 com.apple.HIToolbox 0x00007fff3f936697 _HandlePopUpMenuSelection8(OpaqueMenuRef*, OpaqueEventRef*, unsigned int, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 409
49 com.apple.HIToolbox 0x00007fff3f7fee3c _HandlePopUpMenuSelectionWithDictionary + 268
50 com.apple.AppKit 0x00007fff3dd657ea _NSSLMPopUpCarbonMenu3 + 5632
51 com.apple.AppKit 0x00007fff3de690ec -[NSCarbonMenuImpl _popUpContextMenu:withEvent:forView:withFont:] + 215
52 com.apple.AppKit 0x00007fff3de68f54 -[NSMenu _popUpContextMenu:withEvent:forView:withFont:] + 201
53 com.adobe.Acrobat.framework 0x0000000103566d49 0x10328a000 + 3001673
54 com.adobe.Acrobat.framework 0x00000001035689f9 0x10328a000 + 3009017
55 com.adobe.Acrobat.framework 0x0000000103b8e00d 0x10328a000 + 9453581
56 com.adobe.Acrobat.framework 0x00000001038b34bc 0x10328a000 + 6460604
57 com.adobe.Acrobat.framework 0x00000001038b4f6a 0x10328a000 + 6467434
58 com.adobe.Acrobat.framework 0x0000000103a80c92 0x10328a000 + 8350866
59 com.adobe.Acrobat.framework 0x0000000103a80b1e 0x10328a000 + 8350494
60 com.adobe.Acrobat.framework 0x0000000103c6fb57 0x10328a000 + 10378071
61 com.adobe.Acrobat.framework 0x0000000103c6c01d 0x10328a000 + 10362909
62 com.apple.AppKit 0x00007fff3e3f01a5 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 5040
63 com.apple.AppKit 0x00007fff3e3ee9d8 -[NSWindow(NSEventRouting) sendEvent:] + 497
64 com.apple.AppKit 0x00007fff3e2501ef -[NSApplication(NSEvent) sendEvent:] + 2751
65 com.apple.AppKit 0x00007fff3dab1835 -[NSApplication run] + 812
66 com.adobe.Acrobat.framework 0x00000001032929dd 0x10328a000 + 35293
67 com.adobe.Acrobat.framework 0x00000001032911fe RunAcrobat + 246
68 com.adobe.Acrobat.Pro 0x000000010327ff47 main + 86
69 libdyld.dylib 0x00007fff67a03145 start + 1
Thread 1:: Dispatch queue: NSOperationQueue 0x60800042f5e0 (QOS: UNSPECIFIED)
0 libsystem_kernel.dylib 0x00007fff67b531d2 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff67ace774 nanosleep + 199
2 com.apple.Foundation 0x00007fff425faa37 +[NSThread sleepForTimeInterval:] + 156
3 com.adobe.Acrobat.framework 0x00000001042f5416 0x10328a000 + 17216534
4 com.apple.Foundation 0x00007fff42565dc2 -[__NSOperationInternal _start:] + 778
5 com.apple.Foundation 0x00007fff42561deb __NSOQSchedule_f + 369
6 libdispatch.dylib 0x00007fff679c9f64 _dispatch_client_callout + 8
7 libdispatch.dylib 0x00007fff679dd091 _dispatch_continuation_pop + 472
8 libdispatch.dylib 0x00007fff679d48e0 _dispatch_async_redirect_invoke + 703
9 libdispatch.dylib 0x00007fff679cbb56 _dispatch_root_queue_drain + 515
10 libdispatch.dylib 0x00007fff679cb902 _dispatch_worker_thread3 + 101
11 libsystem_pthread.dylib 0x00007fff67c8d1ca _pthread_wqthread + 1387
12 libsystem_pthread.dylib 0x00007fff67c8cc4d start_wqthread + 13
Thread 2:
0 libsystem_kernel.dylib 0x00007fff67b52e7e __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff67c8e662 _pthread_cond_wait + 732
2 com.adobe.AGM 0x0000000105ab7f30 0x105aab000 + 53040
3 com.adobe.AGM 0x0000000105ab7e6d 0x105aab000 + 52845
4 com.adobe.AGM 0x0000000105e455e5 0x105aab000 + 3778021
5 libsystem_pthread.dylib 0x00007fff67c8d6c1 _pthread_body + 340
6 libsystem_pthread.dylib 0x00007fff67c8d56d _pthread_start + 377
7 libsystem_pthread.dylib 0x00007fff67c8cc5d thread_start + 13
Thread 3:
Thread 4:
Thread 5:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff67b49e76 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff67b49390 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff404a1475 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff404a07c7 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff4049fe43 CFRunLoopRunSpecific + 483
5 com.apple.AppKit 0x00007fff3dbfa1f1 _NSEventThread + 184
6 libsystem_pthread.dylib 0x00007fff67c8d6c1 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff67c8d56d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff67c8cc5d thread_start + 13
Thread 6:
0 com.adobe.Acrobat.framework 0x00000001037c5d16 0x10328a000 + 5487894
1 com.adobe.Acrobat.framework 0x00000001037c6d3e 0x10328a000 + 5492030
2 com.adobe.Acrobat.framework 0x00000001037bb4f5 0x10328a000 + 5444853
3 com.adobe.Acrobat.framework 0x00000001037c779a 0x10328a000 + 5494682
4 com.adobe.Acrobat.framework 0x00000001037f0fda 0x10328a000 + 5664730
5 com.adobe.Acrobat.framework 0x0000000103404631 0x10328a000 + 1549873
6 com.adobe.Acrobat.framework 0x0000000103330a40 0x10328a000 + 682560
7 com.adobe.Acrobat.framework 0x00000001033308ff 0x10328a000 + 682239
8 com.adobe.Acrobat.framework 0x00000001032a43d0 0x10328a000 + 107472
9 com.adobe.Acrobat.framework 0x0000000103404262 0x10328a000 + 1548898
10 com.adobe.Acrobat.framework 0x000000010480b152 0x10328a000 + 22548818
11 com.adobe.Acrobat.framework 0x000000010340094a 0x10328a000 + 1534282
12 com.adobe.Acrobat.framework 0x000000010340054b 0x10328a000 + 1533259
13 com.adobe.AGM 0x0000000105afb44f 0x105aab000 + 328783
14 com.adobe.AGM 0x0000000105afb258 0x105aab000 + 328280
15 com.adobe.AGM 0x0000000105d01768 0x105aab000 + 2451304
16 com.adobe.AGM 0x0000000105ad13e2 0x105aab000 + 156642
17 com.adobe.AGM 0x0000000105acf916 0x105aab000 + 149782
18 com.adobe.AGM 0x0000000105aca3b1 0x105aab000 + 127921
19 com.adobe.AGM 0x0000000105ac88d0 0x105aab000 + 121040
20 com.adobe.AGM 0x0000000105ac7d6f 0x105aab000 + 118127
21 com.adobe.AGM 0x0000000105af5ff1 0x105aab000 + 307185
22 com.adobe.AGM 0x0000000105af5588 0x105aab000 + 304520
23 com.adobe.AGM 0x0000000105af5350 0x105aab000 + 303952
24 com.adobe.Acrobat.framework 0x00000001033fd29c 0x10328a000 + 1520284
25 com.adobe.Acrobat.framework 0x00000001033fcdcc 0x10328a000 + 1519052
26 com.adobe.Acrobat.framework 0x0000000104c2ec93 0x10328a000 + 26889363
27 com.adobe.Acrobat.framework 0x0000000104c2e7bc 0x10328a000 + 26888124
28 com.adobe.Acrobat.framework 0x0000000104c2c807 0x10328a000 + 26880007
29 libsystem_pthread.dylib 0x00007fff67c8d6c1 _pthread_body + 340
30 libsystem_pthread.dylib 0x00007fff67c8d56d _pthread_start + 377
31 libsystem_pthread.dylib 0x00007fff67c8cc5d thread_start + 13
Thread 7:
2 com.adobe.Acrobat.framework 0x00000001036f3b5b 0x10328a000 + 4627291
3 com.adobe.Acrobat.framework 0x00000001036e45b1 0x10328a000 + 4564401
4 com.adobe.Acrobat.framework 0x00000001043a9d0f 0x10328a000 + 17956111
5 com.adobe.Acrobat.framework 0x00000001036e0062 0x10328a000 + 4546658
6 com.adobe.Acrobat.framework 0x00000001036ee594 0x10328a000 + 4605332
7 libsystem_pthread.dylib 0x00007fff67c8d6c1 _pthread_body + 340
8 libsystem_pthread.dylib 0x00007fff67c8d56d _pthread_start + 377
9 libsystem_pthread.dylib 0x00007fff67c8cc5d thread_start + 13
Thread 8:
0 libsystem_kernel.dylib 0x00007fff67b5403a kevent + 10
1 com.adobe.Acrobat.framework 0x0000000104c39c54 0x10328a000 + 26934356
2 com.adobe.Acrobat.framework 0x0000000104b68bec 0x10328a000 + 26078188
3 libsystem_pthread.dylib 0x00007fff67c8d6c1 _pthread_body + 340
4 libsystem_pthread.dylib 0x00007fff67c8d56d _pthread_start + 377
5 libsystem_pthread.dylib 0x00007fff67c8cc5d thread_start + 13
Thread 9:
0 libsystem_kernel.dylib 0x00007fff67b54592 read + 10
1 com.adobe.Acrobat.framework 0x00000001036e2957 0x10328a000 + 4557143
2 com.adobe.Acrobat.framework 0x00000001036e0d1e 0x10328a000 + 4549918
3 com.adobe.Acrobat.framework 0x00000001036ead46 0x10328a000 + 4590918
4 com.adobe.Acrobat.framework 0x00000001036e0062 0x10328a000 + 4546658
5 com.adobe.Acrobat.framework 0x00000001036ee594 0x10328a000 + 4605332
Thread 10:
5 com.adobe.AcrobatPlugin.EFS 0x0000000109ff393f 0x109fda000 + 104767
6 com.apple.Foundation 0x00007fff4255a6d8 __NSThread__start__ + 1197
Thread 11:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff3f419432 +[NSURLConnection(Loader) _resourceLoadLoop:] + 357
Thread 12:
0 libsystem_kernel.dylib 0x00007fff67b53142 __select + 10
1 com.adobe.AcrobatPlugin.Comments 0x000000011699d4c8 0x11660e000 + 3732680
2 com.adobe.AcrobatPlugin.Comments 0x000000011699d995 0x11660e000 + 3733909
3 com.adobe.AcrobatPlugin.Comments 0x000000011699dd7b 0x11660e000 + 3734907
4 com.adobe.AcrobatPlugin.Comments 0x000000011691daf1 0x11660e000 + 3209969
5 com.adobe.AcrobatPlugin.Comments 0x0000000116b2f65d 0x11660e000 + 5379677
Thread 13:: Dispatch queue: com.apple.root.user-interactive-qos
5 com.apple.Foundation 0x00007fff4254c3f6 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
6 com.apple.AppKit 0x00007fff3dbeed6d -[NSAnimation(NSInternal) _runBlocking] + 403
7 com.apple.AppKit 0x00007fff3dbeeb1c __42-[NSAnimation(NSInternal) _runInNewThread]_block_invoke + 102
8 libdispatch.dylib 0x00007fff679d17a2 _dispatch_call_block_and_release + 12
9 libdispatch.dylib 0x00007fff679c9f64 _dispatch_client_callout + 8
10 libdispatch.dylib 0x00007fff679cbcd9 _dispatch_root_queue_drain + 902
11 libdispatch.dylib 0x00007fff679cb902 _dispatch_worker_thread3 + 101
12 libsystem_pthread.dylib 0x00007fff67c8d1ca _pthread_wqthread + 1387
13 libsystem_pthread.dylib 0x00007fff67c8cc4d start_wqthread + 13
Thread 14:
0 libsystem_kernel.dylib 0x00007fff67b536da __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff67c8d26f _pthread_wqthread + 1552
Thread 15:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.SkyLight 0x00007fff61a743d9 CGSUpdateManager::enable_updates_common() + 565
3 com.apple.SkyLight 0x00007fff61a18c98 CGSUpdateManager::enable_update(unsigned long long) + 320
4 libdispatch.dylib 0x00007fff679d17a2 _dispatch_call_block_and_release + 12
5 libdispatch.dylib 0x00007fff679c9f64 _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fff679de42b _dispatch_queue_serial_drain + 635
7 libdispatch.dylib 0x00007fff679d130e _dispatch_queue_invoke + 373
8 libdispatch.dylib 0x00007fff679df117 _dispatch_root_queue_drain_deferred_wlh + 332
9 libdispatch.dylib 0x00007fff679e2ef0 _dispatch_workloop_worker_thread + 880
10 libsystem_pthread.dylib 0x00007fff67c8d033 _pthread_wqthread + 980
11 libsystem_pthread.dylib 0x00007fff67c8cc4d start_wqthread + 13
Thread 16:
Thread 17:
0 libsystem_pthread.dylib 0x00007fff67c8cc40 start_wqthread + 0
1 ??? 0x4058504320000000 0 + 4636544065607827456
Thread 18:: BackgroundThread
2 com.macromedia.FlashPlayer-10.6.plugin 0x000000012309107b 0x122c00000 + 4788347
3 com.macromedia.FlashPlayer-10.6.plugin 0x0000000122c1986e 0x122c00000 + 104558
4 com.macromedia.FlashPlayer-10.6.plugin 0x0000000123090dec 0x122c00000 + 4787692
5 com.macromedia.FlashPlayer-10.6.plugin 0x0000000123090e52 0x122c00000 + 4787794
6 com.macromedia.FlashPlayer-10.6.plugin 0x0000000123090b68 0x122c00000 + 4787048
Thread 19:: BackgroundThread
Thread 20:: BackgroundThread
Thread 21:: BackgroundThread
Thread 22:: ScriptTimeout
2 com.macromedia.FlashPlayer-10.6.plugin 0x000000012309103e 0x122c00000 + 4788286
3 com.macromedia.FlashPlayer-10.6.plugin 0x0000000122e5be36 0x122c00000 + 2473526
Thread 23:: CoreLoop
3 com.macromedia.FlashPlayer-10.6.plugin 0x0000000122ffdda1 0x122c00000 + 4185505
Thread 24:
0 libsystem_kernel.dylib 0x00007fff67b49eb2 semaphore_wait_trap + 10
1 com.adobe.AIDE 0x00000001064cb972 CTThreading::OSSemaphore::Wait() + 16
2 com.adobe.AIDE 0x00000001064caa1a CTThreading::ThreadSafeQueue::Dequeue() + 22
3 com.adobe.AIDE 0x00000001064caf64 CTThreading::WorkerThread::Start() + 38
4 com.adobe.AIDE 0x00000001064ca76a CTThreading::PthreadStart(void*) + 14
Thread 25:
Thread 26:
0 com.adobe.Acrobat.framework 0x000000010380c144 0x10328a000 + 5775684
1 com.adobe.Acrobat.framework 0x00000001037c2430 0x10328a000 + 5473328
2 com.adobe.Acrobat.framework 0x00000001037c6042 0x10328a000 + 5488706
3 com.adobe.Acrobat.framework 0x00000001038117c6 0x10328a000 + 5797830
4 com.adobe.AIDE 0x00000001064ca42c CTThreading::GenericWorker::DoGenericWorkerTask(void*) + 42
5 com.adobe.AIDE 0x00000001064caf50 CTThreading::WorkerThread::Start() + 18
6 com.adobe.AIDE 0x00000001064ca76a CTThreading::PthreadStart(void*) + 14
Thread 27:
Thread 28:
2 com.adobe.Acrobat.framework 0x0000000104c2ed78 0x10328a000 + 26889592
3 com.adobe.Acrobat.framework 0x0000000104c2e7bc 0x10328a000 + 26888124
4 com.adobe.Acrobat.framework 0x0000000104c2c807 0x10328a000 + 26880007
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000060c00025bd20 rbx: 0x0000608000415c60 rcx: 0x0000000000000008 rdx: 0x0000000000000695
rdi: 0x0000608000415c60 rsi: 0x00000001055262d3 rbp: 0x00007ffeec97d5e0 rsp: 0x00007ffeec97d5a8
r8: 0x0000000000000000 r9: 0x000060c00025bd20 r10: 0x00000001057ad980 r11: 0x0000000055242100
r12: 0x0000000000000695 r13: 0x00007fff66e06e80 r14: 0x000060c00025bd20 r15: 0x00007ffeec97d620
rip: 0x00007fff66e06ea9 rfl: 0x0000000000010206 cr2: 0x0000000055242100
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x10327f000 - 0x10327ffff +com.adobe.Acrobat.Pro (17.012.20098 - 17.012.20098) <C8E55D09-69DB-3088-BBCD-BC349D00F1A8> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
0x10328a000 - 0x1055c4fff +com.adobe.Acrobat.framework (17.012.20098 - 17.012.20098) <371FBFF1-8FDF-35D7-A755-86262A6894ED> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
0x10594a000 - 0x105a8fff7 +com.adobe.ACE (AdobeACE 2.20.02.38462 - 2.20.02.38462) <2A4A6267-20BC-325C-931C-E227220B7650> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x105aab000 - 0x105ff3ff7 +com.adobe.AGM (AdobeAGM 4.30.71.1 - 4.30.71.1) <1AE8FCD6-DF0B-3AC2-BA65-4A1715E42219> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x1060a2000 - 0x1060beffb +com.adobe.BIB (AdobeBIB 1.2.03.38462 - 1.2.03.38462) <63152A89-179C-3DE0-94B8-2ED83DA0CC8C> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x1060ca000 - 0x1063bbff7 +com.adobe.CoolType (AdobeCoolType 5.14.05.38664 - 5.14.05.38664) <27B67E54-C758-3E3F-9D84-0CEBB822F603> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x106407000 - 0x10653dfff +com.adobe.AIDE (1.5.0 - 1.5.0.34124) <CE69D37F-2D03-3B1D-8E63-C04CCC3FC37A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x1065b0000 - 0x1065b3fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x107b1d000 - 0x107b1fff3 com.apple.textencoding.unicode (4.0 - 4.0) <B2304E3E-5ECA-30E0-8387-AFB1AE0B659D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x107cb8000 - 0x107cbdfff com.apple.URLMount.CIFSPlugin (7.2 - 7.1) <54F632FE-52B4-3EB8-B344-A2F87A6BEBB5> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
0x107cce000 - 0x107cd2fff com.apple.audio.AppleHDAHALPlugIn (280.12 - 280.12) <9ACA0127-E687-3885-9475-1D5E4DD83168> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x107dc2000 - 0x107e0c98f dyld (519.2.1) <002B0442-3D59-3159-BA10-1C0A77859C6A> /usr/lib/dyld
0x109c7f000 - 0x109d24fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 15 - 84.159810) <618E11AC-EC35-3215-B2A2-328781C36438> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x109dfd000 - 0x109f3bfff +com.adobe.headlights.LogSessionFramework (7.4.1.11.44704) <3FB068A4-9343-3185-870E-F922267BFA19> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/LogSession.framework/LogSession
0x109fda000 - 0x109ffcff7 +com.adobe.AcrobatPlugin.EFS (17.012.20093 - 17.012.20093) <1F3096A1-AEE9-3F71-AE0A-9178CA5B2CF8> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS
0x10afe6000 - 0x10b0eeff7 +com.adobe.amtlib (10.0.0.208 - 10.0.0.208) <DBC068C5-C6D3-3CD7-B157-8AA329981277> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib
0x10b108000 - 0x10b129fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.38656 - 3.9.0.38656) <EF4FC8BF-B277-3F25-9599-B7BE4D8485CC> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x10b14e000 - 0x10b1bbfff +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <FEEA52B6-BF5D-3E45-B99A-05FA2321B856> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite
0x1144fb000 - 0x114646fe7 +IMSLib.dylib (10.0.0.22 - 10.0.0.22) <980F9F58-3C1B-31CC-8E92-226CACCE74C1> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib
0x114b29000 - 0x114b38ff3 +com.adobe.AcrobatPlugin.ReadOutLoud (17.012.20093 - 17.012.20093) <F5101807-53F6-3119-BAA4-6923CD5DE136> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/ReadOutLoud.acroplugin/Contents/MacOS/ReadOutLoud
0x114c12000 - 0x114c36ff7 +com.adobe.AcrobatPlugin.Updater (17.012.20093 - 17.012.20093) <06C442B2-C757-3D6F-9700-B56A61C0F1D4> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Updater.acroplugin/Contents/MacOS/Updater
0x114c84000 - 0x114c88fff +AcrobatUpdateHelperLib.dylib (1) <A8384547-A9BA-3F85-BCA4-4DDE1BD48369> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib
0x114d1d000 - 0x115066ff7 +com.adobe.AcrobatPlugin.EScript (17.012.20093 - 17.012.20093) <EE005D55-600D-3258-A0D9-F8FE48BD329A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EScript.acroplugin/Contents/MacOS/EScript
0x115355000 - 0x115387ff7 +com.adobe.pip (7.4.1.11.44704) <E684FABD-A1CD-329F-80BE-AF6C2FEB415F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x11660e000 - 0x116d6afff +com.adobe.AcrobatPlugin.Comments (17.012.20093 - 17.012.20093) <F93A438A-2DE1-34BF-B5E9-4A7618FDE279> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Comments.acroplugin/Contents/MacOS/Comments
0x117291000 - 0x1172d4fff +com.adobe.AcrobatPlugin.WebLink (17.012.20093 - 17.012.20093) <89A89B48-1F8F-37D7-AD0D-82039AB00389> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/WebLink.acroplugin/Contents/MacOS/WebLink
0x11da8a000 - 0x11dac8ff7 +libcryptocme.dylib (0) <FBB5731B-265B-32EB-A2A2-78FD28833E45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libcryptocme.dylib
0x11dae0000 - 0x11db3eff7 +libccme_base.dylib (0) <59589393-1392-3DAA-8F3F-8840826C9420> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base.dylib
0x11db68000 - 0x11db9efff +libccme_asym.dylib (0) <F7C87F5D-DCB5-3C46-BDB6-5CD936125F18> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_asym.dylib
0x11dbb9000 - 0x11dc7cff7 +libccme_ecc_accel_fips.dylib (0) <ECA407E7-BD54-34A6-B85B-E99EEE6A9F45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc_accel_fips.dylib
0x11dc82000 - 0x11dcebff7 +libccme_ecc.dylib (0) <DA65C6FE-D7F5-305E-BF42-CA3AD7B6C554> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc.dylib
0x11dd21000 - 0x11dd7aff7 +libccme_base_non_fips.dylib (0) <FF0F0C06-3F5D-3BA4-9CFB-E90702E171F1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base_non_fips.dylib
0x11def4000 - 0x11df11fff +com.adobe.PDFSettings (AdobePDFSettings 1.03.0 - 1.3) <7FDF9E77-A5D3-36B1-8372-9B3E3156C138> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/FrameWorks/AdobePDFSettings.framework/AdobePDFSettings
0x11df79000 - 0x11df99ffb +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <1B410608-9714-3731-ADA8-F1BC67CE2A37> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x11dfef000 - 0x11e04dff7 +com.adobe.AcrobatPlugin.Accessibility (17.012.20093 - 17.012.20093) <D8B8B13C-4A99-37A6-B4C8-294BA1ED6B72> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Accessibility.acroplugin/Contents/MacOS/Accessibility
0x11e05f000 - 0x11ee8dff7 +com.adobe.AcrobatPlugin.AcroForm (17.012.20098 - 17.012.20098) <8F00728F-E95C-348A-988B-724A1254EC7E> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/AcroForm.acroplugin/Contents/MacOS/AcroForm
0x11f315000 - 0x11f355ff3 +com.adobe.AcrobatPlugin.Catalog (17.012.20093 - 17.012.20093) <A204A547-FDA5-3FE6-824F-F1F9D290D01A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Catalog.acroplugin/Contents/MacOS/Catalog
0x11f35e000 - 0x11f4cdff7 +com.adobe.AcrobatPlugin.DigSig (17.012.20093 - 17.012.20093) <1E3239EB-1155-3225-B98E-F6C91A835DA9> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/DigSig.acroplugin/Contents/MacOS/DigSig
0x11f4e6000 - 0x11f735ff7 +com.adobe.AcrobatPlugin.HTML2PDF (17.012.20093 - 17.012.20093) <015FC5AA-95FC-37A5-A3FA-F425004D45E4> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/HTML2PDF.acroplugin/Contents/MacOS/HTML2PDF
0x11f76f000 - 0x11f94ffff +com.adobe.AcrobatPlugin.Multimedia (17.012.20093 - 17.012.20093) <C20EFE41-B1C4-3B61-A4EC-4ACC9A3B5055> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Multimedia.acroplugin/Contents/MacOS/Multimedia
0x11f977000 - 0x12031bff7 +com.adobe.AcrobatPlugin.PPKLite (17.012.20093 - 17.012.20093) <6614076F-C6EE-3DD6-88D2-F3A30093510F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/PPKLite.acroplugin/Contents/MacOS/PPKLite
0x1203ad000 - 0x12041cff7 +com.adobe.AcrobatPlugin.Search (17.012.20093 - 17.012.20093) <34B75F91-D7A5-38C3-A6EB-4020697E12CD> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Search.acroplugin/Contents/MacOS/Search
0x120427000 - 0x12061abd3 +com.adobe.AcrobatPlugin.SendMail (17.012.20093 - 17.012.20093) <FAE55402-6E8F-3437-89E0-C97A0E4E2F1F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/SendMail.acroplugin/Contents/MacOS/SendMail
0x120657000 - 0x1206b0ff7 +com.adobe.AcrobatPlugin.Spelling (17.012.20093 - 17.012.20093) <FBD76637-5523-3D98-A237-8B8D218268F1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Spelling.acroplugin/Contents/MacOS/Spelling
0x1206bb000 - 0x121400fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x121414000 - 0x121517ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x121562000 - 0x1215deff7 +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <4D65F948-FC77-3DCB-8370-995E98502B48> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x1215f6000 - 0x121ceeff7 +com.adobe.AcrobatPlugin.TouchUp (17.012.20098 - 17.012.20098) <BB228203-D620-3C31-BA37-55FFFD28EFA9> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/TouchUp.acroplugin/Contents/MacOS/TouchUp
0x121de4000 - 0x121edaff7 +com.lextek.onix (3.16.2.5 - 3.16.2.5) <2046F9B8-054F-3E19-AEDB-39425D893D4A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Onix.framework/Onix
0x122c00000 - 0x1244d8e4f +com.macromedia.FlashPlayer-10.6.plugin (27.0.0.130 - 27.0.0.130) <304DC7A0-E78A-31FD-B7AD-F5F5EE13CC6C> /Library/Internet Plug-Ins/Flash Player.plugin/Contents/PlugIns/FlashPlayer-10.6.plugin/Contents/MacOS/FlashPlayer-10.6
0x7fff38e50000 - 0x7fff38e6cffb libJapaneseConverter.dylib (70) <3CEF6160-E84C-3512-9252-88181B28C8C5> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x7fff38ed2000 - 0x7fff3921fff7 com.apple.RawCamera.bundle (8.00 - 1017) <D3303D4B-A3CE-30C0-9612-5E73FFE8A2C0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff3ad80000 - 0x7fff3b6d7fff com.apple.GeForceGLDriver (10.24.28 - 10.2.4) <9F11029C-6FEF-3691-99C0-0E640D129385> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x7fff3b6d8000 - 0x7fff3bd92ff7 libclh.dylib (10.24.28) <40F91B76-3ADE-39FF-9B34-F23E70B4B50B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x7fff3bd93000 - 0x7fff3bf2fff7 com.apple.GeForceMTLDriver (10.24.28 - 10.2.4) <D6CDE36D-034E-3583-B022-A0400A1FE55C> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
0x7fff3c6ae000 - 0x7fff3c6b2ffb com.apple.agl (3.3.1 - AGL-3.3.1) <2C807327-4E3E-3153-A943-A2264DFCF41C> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff3c6b3000 - 0x7fff3c888ff3 com.apple.avfoundation (2.0 - 1334) <9080A91E-6634-3BC7-BFA3-ED58736B0B25> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff3c889000 - 0x7fff3c940ff7 com.apple.audio.AVFAudio (1.0 - ???) <0AF373D0-B01B-31BC-85E0-FA09AEB79803> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff3ca50000 - 0x7fff3ca50fff com.apple.Accelerate (1.11 - Accelerate 1.11) <04FC5A30-0382-3FEB-BE8B-E14E9FF4EBD5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff3ca51000 - 0x7fff3ca67fe3 libCGInterfaces.dylib (417) <27E09D39-51B5-3297-BE33-0DB1736B833A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff3ca68000 - 0x7fff3cf66fc3 com.apple.vImage (8.1 - ???) <310976EE-E12D-39D7-8F58-6EE924E08576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff3cf67000 - 0x7fff3d0c1fcb libBLAS.dylib (1211) <10BFDBE2-C8FB-39E3-A204-BC6420663E57> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff3d0c2000 - 0x7fff3d0effef libBNNS.dylib (32) <9CA15DC6-004A-32FD-BFCA-F5D488012C43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff3d0f0000 - 0x7fff3d4b0ff7 libLAPACK.dylib (1211) <4560987F-B203-366F-B2CA-3291BCFB511A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff3d4b1000 - 0x7fff3d4c6ff7 libLinearAlgebra.dylib (1211) <3ECB936A-1D5A-3BEE-A9A2-248EF132CE3F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff3d4c7000 - 0x7fff3d4ccff3 libQuadrature.dylib (3) <3D6BF66A-55B2-3692-BAC7-DEB0C676ED29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff3d4cd000 - 0x7fff3d52bfff libSparse.dylib (79.1.1) <7AD0F8A8-FD36-36FE-B83D-58648EBD0027> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff3d52c000 - 0x7fff3d53ffff libSparseBLAS.dylib (1211) <547C43FB-0243-340A-9B9B-AE8E5A5653BA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff3d540000 - 0x7fff3d6dffd7 libvDSP.dylib (622) <8513CE23-5854-31B3-9CDE-25AE9978409B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff3d6e0000 - 0x7fff3d790feb libvMisc.dylib (622) <40CF36D9-8EDE-332B-BB4E-CD9D7BCBEEF5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff3d791000 - 0x7fff3d791fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <97572EBF-43F0-314F-AB29-4281E4A3CD41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff3d792000 - 0x7fff3d7e9fff com.apple.Accounts (113 - 113) <C0FFCA63-0C87-3EB8-A02E-F81006532CE9> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff3d7ea000 - 0x7fff3da7affb com.apple.AddressBook.framework (11.0 - 1805) <7607CB01-DB67-3604-8F38-0BA0623A44A7> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff3da7b000 - 0x7fff3e8d6ff3 com.apple.AppKit (6.9 - 1561.0.100) <791A7190-E21D-3513-9BB0-F2721814A9CD> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff3e928000 - 0x7fff3e928fff com.apple.ApplicationServices (48 - 50) <FB589B1C-2A76-3F1E-A258-3E12338E8BFC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff3e929000 - 0x7fff3e98ffff com.apple.ApplicationServices.ATS (377 - 445) <2303339C-5E2A-37DB-B2B0-E4E5DA9121E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff3ea28000 - 0x7fff3eb4aff7 libFontParser.dylib (222.1) <611B6E36-289C-33C9-BF77-B9D13F481F33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff3eb4b000 - 0x7fff3eb95ff7 libFontRegistry.dylib (221) <A22F82C0-B4FE-3DB5-B968-79B28257DF2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff3ec3a000 - 0x7fff3ec6dff7 libTrueTypeScaler.dylib (222.1) <60C263D2-7388-3640-A243-F819798C1B0B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff3ecd7000 - 0x7fff3ecdbff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <7C8AD42D-5A89-3BA6-B55D-374D9267E939> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff3ed7b000 - 0x7fff3edcdff7 com.apple.HIServices (1.22 - 622) <2E83CD6F-ED98-3C29-BD0A-8525E38AB5DB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff3edce000 - 0x7fff3eddcfff com.apple.LangAnalysis (1.7.0 - 1.7.0) <71A9C815-AC55-3E36-A618-F6778F5119AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff3eddd000 - 0x7fff3ee29fff com.apple.print.framework.PrintCore (13 - 503) <BC23C22A-7691-3BD4-8013-BAAE3A44763C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff3ee2a000 - 0x7fff3ee64fff com.apple.QD (3.12 - 403) <38D8106A-4FFA-3FE9-9999-714CADD7EE9C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff3ee65000 - 0x7fff3ee71fff com.apple.speech.synthesis.framework (7.0.14 - 7.0.14) <C8AACF93-9FF5-32FE-A448-E174702509FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff3ee72000 - 0x7fff3f0fbfff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <D451B82D-A397-38F0-87CE-D67DB3123365> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff3f0fd000 - 0x7fff3f0fdfff com.apple.audio.units.AudioUnit (1.14 - 1.14) <29B5E5A8-51D1-3528-866E-C4D3B78F80A0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff3f413000 - 0x7fff3f776fff com.apple.CFNetwork (887 - 887) <D7DDB735-A244-3A06-A432-135E9E368B51> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff3f78b000 - 0x7fff3f78bfff com.apple.Carbon (158 - 158) <C34E5FF0-4FDA-35F1-85C2-FDAC4EDE8331> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3f78c000 - 0x7fff3f78fffb com.apple.CommonPanels (1.2.6 - 98) <39C8EBA3-EEB2-335B-8A88-D6C64BAA112F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3f790000 - 0x7fff3fa94ff7 com.apple.HIToolbox (2.1.1 - 909.1) <39EA833C-2FAD-33B9-BB99-7BDCBCE4B08A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3fa95000 - 0x7fff3fa98ffb com.apple.help (1.3.8 - 64) <18D02016-119A-33E8-AEB0-E9466BA4AD56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff3fa99000 - 0x7fff3fa9efff com.apple.ImageCapture (9.0 - 9.0) <2DE590E5-DF0E-3962-A2BE-06EBC79B3D72> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff3fa9f000 - 0x7fff3fb34ffb com.apple.ink.framework (10.9 - 220) <D8AECAE3-9FD2-32E3-B659-026F33650BB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff3fb35000 - 0x7fff3fb4fff7 com.apple.openscripting (1.7 - 174) <1CF64DD1-144D-3702-A728-1F476E1A00ED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff3fb70000 - 0x7fff3fb71fff com.apple.print.framework.Print (12 - 267) <E4CBAAFC-9045-38AC-9F93-8C931DDED9D8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3fb72000 - 0x7fff3fb74ff7 com.apple.securityhi (9.0 - 55006) <E7668200-B4CB-3612-96B8-D57E94077787> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff3fb75000 - 0x7fff3fb7bfff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1F10ED1F-12C7-39AC-88A0-43A1338F9316> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff3fc87000 - 0x7fff3fc87fff com.apple.Cocoa (6.11 - 22) <3614E923-D790-370A-95EC-42124C76796E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff3fc95000 - 0x7fff3fd4eff7 com.apple.ColorSync (4.13.0 - 544) <E959C37C-099B-3DD8-AB3B-67F0625939F7> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff3fed9000 - 0x7fff3ff6cff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <505A5EFB-6BCD-3E94-936F-1722C67F608E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff3ffd3000 - 0x7fff3fffcffb com.apple.CoreBluetooth (1.0 - 1) <942F88A5-AD68-3359-90D5-6F1A3311C51A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3fffd000 - 0x7fff4034efeb com.apple.CoreData (120 - 847.1) <9B5E7B0B-1957-3D56-99CA-6422123D300C> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff4034f000 - 0x7fff4041afff com.apple.CoreDisplay (1.0 - 79.7) <BADA099E-BE1F-3F98-9053-722FB0ECBFBA> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff4041b000 - 0x7fff408bafff com.apple.CoreFoundation (6.9 - 1443.13) <2881430B-73E5-32C1-B62D-7CEB68A616F5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff408bc000 - 0x7fff40ec8fef com.apple.CoreGraphics (2.0 - 1125.1.1) <425F5F16-3EAF-3B74-BC6B-A0A5FCE6AFF1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff40eca000 - 0x7fff411bfff7 com.apple.CoreImage (13.0.0 - 573) <7949E071-A3C0-30BB-B21D-79992CBE82DA> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff4142e000 - 0x7fff41509ffb com.apple.CoreMedia (1.0 - 2074.3) <A11F305C-75BB-33E2-95F8-9B83B6C8A574> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff4150a000 - 0x7fff41558fff com.apple.CoreMediaIO (803.0 - 4976) <F25F26B6-0DA6-3573-B8DC-4911F01519F6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff41559000 - 0x7fff41559fff com.apple.CoreServices (822.9 - 822.9) <0FF1E8AB-F09A-363F-8839-10D5BBE8F2F4> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff4155a000 - 0x7fff415ceff7 com.apple.AE (733 - 733) <09481487-37C2-359E-9E9A-7393B7C8643B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff415cf000 - 0x7fff418a6ff7 com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <A1FE74F8-953B-371E-A8AC-E87B30FB79C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff418a7000 - 0x7fff418dbff7 com.apple.DictionaryServices (1.2 - 284) <3FCEE280-8DD0-37C9-BFD4-7BA87AAFC8EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff418dc000 - 0x7fff418e4ff3 com.apple.CoreServices.FSEvents (1239 - 1239) <7BBC5CB7-DBC8-316B-99B0-781827159A2F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff418e5000 - 0x7fff41a9cfff com.apple.LaunchServices (822.9 - 822.9) <E181C2C2-7283-3653-8E19-DA69EBE529E7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff41a9d000 - 0x7fff41b4cff3 com.apple.Metadata (10.7.0 - 1191) <32C57F7B-DAC3-3F12-8DEA-1CB5A062DC02> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff41b4d000 - 0x7fff41baaff7 com.apple.CoreServices.OSServices (822.9 - 822.9) <C91ABD5F-1FE3-3108-AB5E-BF90D56D1F55> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff41bab000 - 0x7fff41c19fff com.apple.SearchKit (1.4.0 - 1.4.0) <14053F88-2C76-35CA-9FC1-2A9BC0B63F88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff41c1a000 - 0x7fff41c3effb com.apple.coreservices.SharedFileList (71.2 - 71.2) <41713411-2729-39F9-951A-DE39A00495F0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff41c3f000 - 0x7fff41c9aff7 com.apple.CoreSpotlight (1.0 - 229) <83BB5E52-4F0B-3E1F-B105-45191C05F7C9> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
0x7fff41ed8000 - 0x7fff42025fff com.apple.CoreText (352.0 - 578.3) <8A8D96F6-1FBE-320F-A60B-37F63FE20D89> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff42026000 - 0x7fff42060fff com.apple.CoreVideo (1.8 - 278.0) <9C66B618-8582-3731-A0F1-36FDD730FB07> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff42061000 - 0x7fff420ebffb com.apple.framework.CoreWLAN (13.0 - 1335) <D9A8EA05-FE12-322E-8761-F05A68DA8B3B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff42278000 - 0x7fff42283ff7 com.apple.DirectoryService.Framework (10.13 - 207) <CC596F1F-16FB-3C22-8D21-E69B6BAA64B4> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff42365000 - 0x7fff4236afff com.apple.DiskArbitration (2.7 - 2.7) <44836CE9-A9ED-3017-972A-7A0A3D6B472B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff4252b000 - 0x7fff428eefff com.apple.Foundation (6.9 - 1443.14) <360EB3B4-CD31-380E-8E77-4954559F97F8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff4295e000 - 0x7fff4298eff7 com.apple.GSS (4.0 - 2.0) <EA4ADB9D-FB33-3D20-BE11-7F833988FDD9> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff42a9f000 - 0x7fff42ba2ffb com.apple.Bluetooth (6.0.0 - 6.0.0f7) <6C809D0F-049E-3CDB-AB86-54BD3809D79C> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff42c02000 - 0x7fff42c9dfff com.apple.framework.IOKit (2.0.2 - 1445.1.3) <06331786-CF08-3225-B27B-80754BA0ECB6> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff42c9f000 - 0x7fff42ca5ffb com.apple.IOSurface (209 - 209) <507843CC-3C5D-3548-B86D-4564123F3993> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff42ca6000 - 0x7fff42cf9ff7 com.apple.ImageCaptureCore (7.0 - 7.0) <08AD8B51-AF58-348A-9988-61AABDF987D6> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff42cfa000 - 0x7fff42e6cfff com.apple.ImageIO.framework (3.3.0 - 1694) <836F3C70-F8C1-3736-823F-B3A04C0083B0> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff42e6d000 - 0x7fff42e71ffb libGIF.dylib (1694) <D2E653D4-00E1-34C4-B0A4-2D4DD667F236> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff42e72000 - 0x7fff42f59fff libJP2.dylib (1694) <5C071A03-A7F6-33D6-98B7-EACD0D28F72E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff42f5a000 - 0x7fff42f7dff7 libJPEG.dylib (1694) <3CB66E19-AD25-3C50-A0A8-48B6C6A1187E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff43259000 - 0x7fff4327ffeb libPng.dylib (1694) <B81D1334-160D-397C-ACAE-D36BEB14B615> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff43280000 - 0x7fff43282ffb libRadiance.dylib (1694) <E3E525DA-1601-3942-8E6D-43CE368E9D1E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff43283000 - 0x7fff432d0fff libTIFF.dylib (1694) <99AA8DE9-04F1-3FBB-995F-6CD2F56AC295> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff4348a000 - 0x7fff43feffff com.apple.JavaScriptCore (13604 - 13604.1.38.1.6) <5C66D28E-F1EE-3A31-A298-3F77DC292126> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff44007000 - 0x7fff44020ff7 com.apple.Kerberos (3.0 - 1) <CAF075C0-4C24-3ACE-9AE6-77BEFDEA3622> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff44021000 - 0x7fff44056fff com.apple.LDAPFramework (2.4.28 - 194.5) <8419BDB5-12DF-3BC9-871D-7A270E080249> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff442d2000 - 0x7fff442d9fff com.apple.MediaAccessibility (1.0 - 114) <D72C593A-AC32-3419-AB86-6B07217EBFD5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff44365000 - 0x7fff44961ff7 com.apple.MediaToolbox (1.0 - 2074.3) <1D00A19E-D592-3CC0-A6CC-16E540950070> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff44963000 - 0x7fff449e2ff7 com.apple.Metal (123.3.5 - 123.3.5) <ED65B003-6CE3-3EC7-9E0F-E7F2FA8DC63B> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff449fd000 - 0x7fff44a12fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <D3685A4F-533C-39A6-80B6-7CCA49234329> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff44a13000 - 0x7fff44a7dfef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <50B454D2-5D46-394E-B089-AC3242FEA9A2> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff44a7e000 - 0x7fff44a9dfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <0D5F11B0-476D-34EB-8CD0-491BEDA5E4F2> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff44a9e000 - 0x7fff44b14ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <A4E950B8-380B-3561-8EA4-5C07C3F43816> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff44b15000 - 0x7fff44b15ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <02E0B95E-1F7C-317A-AF09-149E01D2D641> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff45b20000 - 0x7fff45b2cffb com.apple.NetFS (6.0 - 4.0) <81B22AE7-7094-30F2-BF41-84CA05EDB95B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff48983000 - 0x7fff4898bfef libcldcpuengine.dylib (2.8.7) <DD781325-D94E-3AD7-8D6C-817FB3068917> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff4898c000 - 0x7fff489d9ffb com.apple.opencl (2.8.11 - 2.8.11) <8A7F27CA-DD5A-38F0-BE6F-01ECCB05C5A3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff489da000 - 0x7fff489f6ffb com.apple.CFOpenDirectory (10.13 - 207) <582A03AA-A51C-3DAE-AC03-FA1CEE0C5896> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff489f7000 - 0x7fff48a02fff com.apple.OpenDirectory (10.13 - 207) <AAECC5AB-F4ED-38CB-8A7D-7736D97F980A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff49b81000 - 0x7fff49b83fff libCVMSPluginSupport.dylib (16.0.3) <5F651C63-E9B9-3794-B541-71B4B6157DD7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff49b84000 - 0x7fff49b87ff7 libCoreFSCache.dylib (160.9) <FF64C4CC-F262-3176-B06A-632C47CD636B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff49b88000 - 0x7fff49b8cfff libCoreVMClient.dylib (160.9) <390D5A60-55BB-3D7B-928B-52BFCA05FD07> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff49b8d000 - 0x7fff49b95fff libGFXShared.dylib (16.0.3) <F0AAA768-B2EB-336B-877C-3F817E78E766> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff49b96000 - 0x7fff49ba1fff libGL.dylib (16.0.3) <6EB2A446-73D8-30B6-97DA-31CB1C42BA27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff49ba2000 - 0x7fff49bddfe7 libGLImage.dylib (16.0.3) <A8B1C0BD-6DE9-3C3C-8DDB-AC72DA87BA90> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff49bde000 - 0x7fff49d4afff libGLProgrammability.dylib (16.0.3) <D4D53DAC-F45B-34AD-AAD0-815D0F53D157> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff49d4b000 - 0x7fff49d89ffb libGLU.dylib (16.0.3) <4F964A5D-BC47-368B-88F7-76DA28C2D8AE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff4a701000 - 0x7fff4a70fffb com.apple.opengl (16.0.3 - 16.0.3) <8B17A8DE-89F5-3E2E-897E-315003386475> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff4a710000 - 0x7fff4a8a7ffb GLEngine (16.0.3) <331925D2-4E17-3BA4-8577-C215CE658ACA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff4a8a8000 - 0x7fff4a8d0ffb GLRendererFloat (16.0.3) <858E25C4-4B7B-317E-897A-C3B66A47BD80> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff4aa87000 - 0x7fff4abd3fff com.apple.QTKit (7.7.3 - 3014) <CF2818E6-E215-3C24-A2AC-1B5F8AD7E398> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff4abd4000 - 0x7fff4ae39fff com.apple.imageKit (3.0 - 1038) <A5FCC298-F523-3999-8BC1-A076FF9BA506> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff4ae3a000 - 0x7fff4af32fff com.apple.PDFKit (1.0 - 662.1.5) <ACC40859-6B78-39EB-8D29-E9C6763344C6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff4af33000 - 0x7fff4b445ff7 com.apple.QuartzComposer (5.1 - 364) <D99600D5-C066-3D49-8641-369A69300D16> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff4b446000 - 0x7fff4b469fff com.apple.quartzfilters (1.10.0 - 1.10.0) <8CBE10F3-828F-373C-B92A-A5289CBCF77A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff4b46a000 - 0x7fff4b561fff com.apple.QuickLookUIFramework (5.0 - 743.3) <464A71CB-B356-3E9F-91A7-4179095E6F64> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff4b562000 - 0x7fff4b562fff com.apple.quartzframework (1.5 - 21) <3F3BE91F-A032-3E92-ACEA-E2DFEC999E93> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff4b563000 - 0x7fff4b7a7fff com.apple.QuartzCore (1.11 - 574.1.4) <D7CFDB66-4913-33AE-98BB-83F2F3EE26DB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff4b7a8000 - 0x7fff4b7fffff com.apple.QuickLookFramework (5.0 - 743.3) <DB4CAFA3-4F4F-3802-A1CA-197BC4C55F15> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff4b9c4000 - 0x7fff4b9dafff com.apple.SafariServices.framework (13604 - 13604.1.38.1.6) <2CCE692D-BB88-30BF-B819-13E7D34F178B> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff4bfc4000 - 0x7fff4bfdbfff com.apple.ScriptingBridge (1.3.3 - 70) <44B47809-18BF-3522-B6A0-7C14AA4BE979> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff4bfdc000 - 0x7fff4c2f6fff com.apple.security (7.0 - 58286.1.33) <210FF9A7-CD6E-3FFB-9935-45A3FEEB89A1> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff4c2f7000 - 0x7fff4c380ff7 com.apple.securityfoundation (6.0 - 55185.1.1) <917915A4-7A79-3C42-9695-CFD0D9830778> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff4c381000 - 0x7fff4c3aefff com.apple.securityinterface (10.0 - 55109.1.1) <5BAAC4F5-9909-3D93-AAC8-EDF9A65ADB63> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff4c3af000 - 0x7fff4c3b2ffb com.apple.xpc.ServiceManagement (1.0 - 1) <3763B3EF-0573-36A6-9647-8EBB139B9CAC> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff4c756000 - 0x7fff4c7c6ffb com.apple.SystemConfiguration (1.17 - 1.17) <77EB81C7-7017-3777-BCB7-8DD078ABE25D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff4c97b000 - 0x7fff4ccf3fff com.apple.VideoToolbox (1.0 - 2074.3) <BD5A9A0B-4260-3F4C-A030-5F8F9D51B481> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff4cf95000 - 0x7fff4d4aeff3 libwebrtc.dylib (7604.1.38.1.6) <90B931F0-49B0-39C4-A46D-98CDC8FD19C7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff4d4af000 - 0x7fff4e93dfff com.apple.WebCore (13604 - 13604.1.38.1.6) <5C6E88AC-7182-344B-85B9-CC24931ECCBB> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff4e93e000 - 0x7fff4eb2ffff com.apple.WebKitLegacy (13604 - 13604.1.38.1.6) <AECB7486-5259-3732-A4FF-0A6942ECA644> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff4eb30000 - 0x7fff4ef1ffff com.apple.WebKit (13604 - 13604.1.38.1.6) <C91F1396-BBC1-3DB8-87B8-3E47853F115B> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff4f38a000 - 0x7fff4f414fef com.apple.APFS (1.0 - 1) <BF3E8416-3064-34E2-90BE-C92CC98B38A7> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4fff5000 - 0x7fff5001dfff com.apple.framework.Apple80211 (13.0 - 1335) <0E4FD4E0-D582-3983-A6C8-18D1EA27FBC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff5001f000 - 0x7fff5002efef com.apple.AppleFSCompression (96.1.1 - 1.0) <B24CC74D-7B69-3313-9DC1-8E8B3E9EEBA2> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff50168000 - 0x7fff501b0fff com.apple.AppleJPEG (1.0 - 1) <DCAB2588-8879-3A64-87EA-EAA770BA1ADB> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff501c3000 - 0x7fff501e1ff7 com.apple.aps.framework (4.0 - 4.0) <A1BA3B04-8E53-3479-AA0C-B4404BF53982> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff501e2000 - 0x7fff501eaff3 com.apple.AppleSRP (5.0 - 1) <4CEC34CF-63E3-3023-B61B-F8D133698534> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff501eb000 - 0x7fff50213fff com.apple.applesauce (1.0 - ???) <32FF4851-2F68-35BA-835F-91856A20C323> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff502dc000 - 0x7fff502dfff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A6795AC1-D528-3A2F-9C43-14EBFC57B7D6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff502e0000 - 0x7fff50330ff7 com.apple.AppleVAFramework (5.0.39 - 5.0.39) <754413E6-FFD1-3CE4-9932-2977AD675319> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff509d2000 - 0x7fff509d9ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <7F54A7A8-3667-3071-9DE6-2D915C63F70C> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff509da000 - 0x7fff50a61ff7 com.apple.backup.framework (1.9 - 1.9) <3C2E6CB6-3A16-309D-B1E2-ED3930CEE91E> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff50ad5000 - 0x7fff50b11fff com.apple.bom (14.0 - 194.2) <ED2FFB9D-4DA4-322B-89C0-102D790649CD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff51107000 - 0x7fff51134fff com.apple.CalendarAgentLink (8.0 - 250) <37D477DA-9DC9-340F-927E-D16CB4EC72D8> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fff517f9000 - 0x7fff51848ff3 com.apple.ChunkingLibrary (186 - 186) <1009BA1B-B479-36B1-9A07-752DD204BBA6> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff5184f000 - 0x7fff518defff com.apple.CloudDocs (1.0 - 559) <7E2A74CA-EA11-316D-8FD1-2FD8D31E91AF> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff523b7000 - 0x7fff523c0ffb com.apple.CommonAuth (4.0 - 2.0) <F9A7C82E-197F-382E-B854-3DCE83FD6DA3> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff523d5000 - 0x7fff523e9ff7 com.apple.commonutilities (8.0 - 900) <9285EF18-980C-3CF0-856E-C5D3A5276F7D> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff5256b000 - 0x7fff525cbffb com.apple.AddressBook.ContactsFoundation (8.0 - ???) <9B05C7D3-BB29-356C-935F-8D2C435B4F36> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff525cc000 - 0x7fff525eefff com.apple.contacts.ContactsPersistence (1.0 - 2326) <AFEBD9C8-11BB-38DD-9474-94990F194220> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff5264e000 - 0x7fff52a2efff com.apple.CoreAUC (249.0.0 - 249.0.0) <7F406271-A215-3C75-BDAA-B9611BA2822E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff52a2f000 - 0x7fff52a5fff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <D0879D8F-488A-3D46-BC50-AD7B0642C0E8> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff52c57000 - 0x7fff52c60ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <0A87A91C-A2CF-3BB1-9038-7F610111BC30> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff52dc4000 - 0x7fff52dd4ff7 com.apple.CoreEmoji (1.0 - 69) <3945FA6E-D060-3F9F-B392-4228E6630F67> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff5368f000 - 0x7fff536a5ff7 com.apple.CoreMediaAuthoring (2.2 - 956) <A5003E93-68B3-3A0E-8252-454CC4CFEC4D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff537e7000 - 0x7fff53843fff com.apple.CoreNLP (1.0 - 129) <4D51E55E-2D8D-3C35-B2D1-FCBCCF2B77E5> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff539cc000 - 0x7fff539d1ff7 com.apple.CoreOptimization (1.0 - 1) <785B622B-8F7D-3B4D-83AF-EB98CB79FFF6> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff539d2000 - 0x7fff53a6eff7 com.apple.CorePDF (4.0 - 414) <259556DC-97EB-335D-90F0-D0E42FB4AA95> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff53b06000 - 0x7fff53b0eff7 com.apple.CorePhoneNumbers (1.0 - 1) <88C31D1D-6611-345F-BF8B-635EC10DB2E5> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff53b0f000 - 0x7fff53b6bfff com.apple.CorePrediction (1.0 - 1) <B1E687BA-4E62-321B-8C87-D37C540A5A68> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff53c97000 - 0x7fff53cc8ff3 com.apple.CoreServicesInternal (309 - 309) <CB3D74CC-1568-3E66-8015-2A3D11BCAF21> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff53fed000 - 0x7fff5407efff com.apple.CoreSymbolication (63075) <22359913-3FAE-3FE3-9F88-F3521169FB4E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff54101000 - 0x7fff54235fd7 com.apple.coreui (2.1 - 489) <8DAE0B7F-186E-333F-8B8E-941DB03BF2FC> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff54236000 - 0x7fff5432fffb com.apple.CoreUtils (5.2 - 520.68) <7F80020B-0208-38A7-B333-EC1463FF1AA4> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff54384000 - 0x7fff543e8fff com.apple.framework.CoreWiFi (13.0 - 1335) <AEF55AE3-983E-31D0-A578-61284964339C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff543e9000 - 0x7fff543f8ff7 com.apple.CrashReporterSupport (10.13 - 1) <842680F4-0BFB-386A-A32D-E9ED39DCE790> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff543f9000 - 0x7fff54468fff com.apple.DCERPC (2.0 - 63) <1A67096F-3EDC-3537-A9A1-4E54E3E77EF1> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
0x7fff54475000 - 0x7fff54484ff7 com.apple.framework.DFRFoundation (1.0 - 189.1) <C7DE4082-6AC1-3971-AAC7-979E33C9D0F1> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff54487000 - 0x7fff5448bffb com.apple.DSExternalDisplay (3.1 - 380) <BEC07C7C-F3AC-3CF3-B13E-3EBFD6224C0D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff544d0000 - 0x7fff54511ff3 com.apple.datadetectors (5.0 - 375) <89B1F001-E7A2-347F-BCE1-2B7957A1D3D2> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x7fff54512000 - 0x7fff54588ff7 com.apple.datadetectorscore (7.0 - 590) <48B788AF-7927-341E-94EE-119561245659> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff545d6000 - 0x7fff54616ff7 com.apple.DebugSymbols (141 - 141) <99562E28-0E56-3F6F-93A1-EF997A5E1F87> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff54617000 - 0x7fff54741ff7 com.apple.desktopservices (1.12 - 1.12) <C6BBDC1D-106A-324A-9325-FCB62F38E7FB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff5479e000 - 0x7fff5479fff7 com.apple.diagnosticlogcollection (10.0 - 1000) <FB2D070B-AA55-38C1-96BB-FF8C7BD22CA0> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x7fff5497b000 - 0x7fff54986ff7 com.apple.DisplayServicesFW (3.1 - 380) <FB1FBB24-7FD5-3B57-8D3C-39F953F8A9BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff55151000 - 0x7fff55169fff com.apple.Engram (1.0 - 1) <5533EDB6-3395-305B-A17C-2A22214BE564> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
0x7fff55494000 - 0x7fff558c2fff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <80C97AD7-D5C2-311A-B268-4AA60CAD6CED> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff558f0000 - 0x7fff55976ffb com.apple.FileProvider (111.1 - 111.1) <57DC140C-1F60-3351-BA67-6A0C07B4CF58> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff5751e000 - 0x7fff5751efff libmetal_timestamp.dylib (802.1.35) <73D8B306-6321-30DB-8522-819344E19AF8> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_timestamp.dylib
0x7fff58b7e000 - 0x7fff58b89ff7 libGPUSupportMercury.dylib (16.0.3) <7C3F6819-4E0A-34A1-A11B-059C51BE0699> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff58f26000 - 0x7fff58f4bff3 com.apple.GenerationalStorage (2.0 - 281) <8BAB613F-84AA-3001-8D14-F1E1BBB7FBF5> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff598c2000 - 0x7fff598d1fff com.apple.GraphVisualizer (1.0 - 5) <0A93C5DE-0D28-312E-8764-6B0FB805ED91> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff59949000 - 0x7fff599bdfff com.apple.Heimdal (4.0 - 2.0) <600A9BD5-3DD2-3F7C-B40E-8485026FE936> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff599be000 - 0x7fff599ebfff com.apple.HelpData (2.3 - 154) <81CDA3EF-246A-3AE5-8705-6F3057FC06F7> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff59a56000 - 0x7fff59b68ff3 com.apple.ids (10.0 - 1000) <C8E10EB7-D298-36C2-A67E-C362DCFC00E8> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fff59b69000 - 0x7fff59c45fff com.apple.idsfoundation (10.0 - 1000) <833CA186-0312-33A0-93A3-A7C0839EFBC0> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fff5a148000 - 0x7fff5a1adfff com.apple.imfoundation (10.0 - 1000) <18D21CE9-961E-3DA4-A6E2-C814CB15036D> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fff5a25d000 - 0x7fff5a264ffb com.apple.IOAccelerator (373 - 373) <22F55498-DF4D-3262-B527-0277E8C6BAA5> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff5a268000 - 0x7fff5a27eff7 com.apple.IOPresentment (1.0 - 32.1) <8F468709-520F-360D-AD51-0E13298B8DC0> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff5a63d000 - 0x7fff5a662ffb com.apple.IconServices (97.3 - 97.3) <9FB00A91-C46B-3CF1-973A-FDDABCEA088D> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff5a769000 - 0x7fff5a76cff3 com.apple.InternationalSupport (1.0 - 1) <0EA71B0F-1B0D-3072-8945-1FD9041A80BD> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff5a7da000 - 0x7fff5a7eaffb com.apple.IntlPreferences (2.0 - 227) <500CB7B9-7BDF-39E6-B355-28E100B28793> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff5a885000 - 0x7fff5a892fff com.apple.KerberosHelper (4.0 - 1.0) <06271ABF-0798-3947-86F7-6FAF863BC56C> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
0x7fff5a8f3000 - 0x7fff5a9e8ff7 com.apple.LanguageModeling (1.0 - 159) <FADD52FC-9B63-3976-9AB1-40230918F84F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff5a9e9000 - 0x7fff5aa2bff7 com.apple.Lexicon-framework (1.0 - 33) <CEF5A399-DFD3-347D-8EEE-8F01038B9900> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff5aa2f000 - 0x7fff5aa36ff7 com.apple.LinguisticData (1.0 - 238) <3DB10488-85F6-3A70-87CF-A2D1B1ABC016> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff5ab6c000 - 0x7fff5ab89ff3 com.apple.LookupFramework (1.2 - 237) <FC452756-F465-387B-9219-84B65A0BCB57> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup
0x7fff5b244000 - 0x7fff5b247fff com.apple.Mangrove (1.0 - 1) <562BB18E-815A-37D1-A373-B46C7853BA94> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff5b2cf000 - 0x7fff5b2d1ff7 com.apple.marco (10.0 - 1000) <88A5D4DB-0A6F-33AA-991E-ED29504040E8> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fff5b60f000 - 0x7fff5b676ff7 com.apple.gpusw.MetalTools (1.0 - 1) <32E08129-AC43-315C-8A14-3CD7BE507850> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff5b67e000 - 0x7fff5b692ff3 com.apple.MobileAssets (1.0 - 437.1.11) <AF26C530-C18C-32BC-881E-CAFAE4CEF8EE> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff5b7e8000 - 0x7fff5b7ffffb com.apple.MobileKeyBag (2.0 - 1.0) <7405128E-E7B0-3EFB-BA65-EA50564E3BCD> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff5b88b000 - 0x7fff5b8b3ff7 com.apple.MultitouchSupport.framework (1004.1 - 1004.1) <69BF94F5-9301-3755-98A1-A981DB03C395> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff5b8b4000 - 0x7fff5b8bcffb com.apple.multiverse (1.0 - 27) <0AF7A4FF-5337-39B8-B507-2ABC7A080235> /System/Library/PrivateFrameworks/MultiverseSupport.framework/Versions/A/MultiverseSupport
0x7fff5bb17000 - 0x7fff5bb22fff com.apple.NetAuth (6.2 - 6.2) <5C6F492A-28EF-3A0E-B573-6F3D60CFF0C7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff5bb2f000 - 0x7fff5bbfcff7 com.apple.Network (1.0 - 1) <35C610C2-A2CB-3894-828B-819C16F55372> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
0x7fff5d2da000 - 0x7fff5d31affb com.apple.PerformanceAnalysis (1.183 - 183) <520FEF4A-4C60-31FA-8BA0-528294BC41ED> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff5d390000 - 0x7fff5d390ff7 com.apple.PhoneNumbers (1.0 - 1) <ECC7CCB3-4903-3677-B0C9-E64F036C64EC> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff5ed70000 - 0x7fff5ed95fff com.apple.pluginkit.framework (1.0 - 1) <5563493F-9BE6-3B11-9261-C330FF14CA16> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff5f0d9000 - 0x7fff5f0f7fff com.apple.ProtocolBuffer (1 - 259) <D047A3FE-C7A8-3CAA-9891-6232BA88C247> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff5f264000 - 0x7fff5f279ff3 com.apple.QuickLookThumbnailing (1.0 - 1) <0771325B-BBAD-3865-B2A3-BE7089641C52> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff5f2bd000 - 0x7fff5f2c6ff3 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.1.10) <488A5851-FDEF-3F70-AEBC-BDCF4E58188A> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff5f2c7000 - 0x7fff5f2eaffb com.apple.RemoteViewServices (2.0 - 125) <AEDBCE8C-88B7-315A-9F81-3E068F0D3EDC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff5f2eb000 - 0x7fff5f2fcff3 com.apple.xpc.RemoteXPC (1.0 - 1205.1.10) <AB4045A3-9A24-39AE-8907-47699B8F36F4> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff5f798000 - 0x7fff5f7b0ff7 com.apple.SMBClient (3.2 - 3.2) <443F0031-7E25-3467-8B25-9BB6B34DCF18> /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient
0x7fff60beb000 - 0x7fff60ce4ff7 com.apple.Sharing (910.7 - 910.7) <465C0170-A544-3713-AB5A-894756E6C13E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff60ce5000 - 0x7fff60d04ff3 com.apple.shortcut (2.16 - 98) <B8A517F6-B872-3A71-B096-709A0CC6656F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff60d0e000 - 0x7fff60d0ffff com.apple.performance.SignpostNotification (1.0 - 1) <5C953AF5-746A-3049-A2BC-901D6C7B583F> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff61a08000 - 0x7fff61c9ffff com.apple.SkyLight (1.600.0 - 312) <9BF6B34C-532F-3F84-9B47-C9121FFF0A01> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff6244c000 - 0x7fff62459ff7 com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <AC026FB9-78F8-31F9-BB80-619D5378DB70> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff6250a000 - 0x7fff62745ff3 com.apple.spotlight.index (10.7.0 - 1191) <7F436FF6-135E-322E-9834-44CF7ED1699A> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff628ee000 - 0x7fff62914ff3 com.apple.StreamingZip (1.0 - 1) <3D46509E-3EB7-3EC8-828D-19BF3C8670BD> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff62fe5000 - 0x7fff63069fe7 com.apple.Symbolication (9.0 - 63079.1) <177BC9CA-E6AE-3B40-806F-0080C0CDFF29> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff6307a000 - 0x7fff63081fff com.apple.SymptomDiagnosticReporter (1.0 - 820.1.4) <29851256-D036-3CF9-9558-D7694D04704F> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff63554000 - 0x7fff6355bff7 com.apple.TCC (1.0 - 1) <1774542A-1E70-3E22-9698-372200D27249> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff63761000 - 0x7fff63822ff7 com.apple.TextureIO (3.4 - 3.4) <7C93B388-7171-3B3D-BD23-0A8280059260> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff63873000 - 0x7fff6388effb com.apple.ToneKit (1.0 - 1) <A0242052-983B-3726-B5BD-D2E672CEFE2F> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff6388f000 - 0x7fff638b6fff com.apple.ToneLibrary (1.0 - 1) <7EEABD7F-D0CB-327E-A772-ACF406B9C8F2> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff638c6000 - 0x7fff638c7fff com.apple.TrustEvaluationAgent (2.0 - 31) <39F533B2-211E-3635-AF47-23F27749FF4A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff638cd000 - 0x7fff63a7cff7 com.apple.UIFoundation (1.0 - 543) <A393DE4F-0885-3C7C-9933-F3AF8D58B93F> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff6473c000 - 0x7fff6480bfff com.apple.ViewBridge (341.1 - 341.1) <53A2272D-E834-3A48-829B-D71E05B9E714> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff64f70000 - 0x7fff64fd0fff com.apple.xquery (1.3.1 - 30) <D18B188E-9D92-3644-9612-6ECB2D9C908F> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
0x7fff65199000 - 0x7fff6519bffb com.apple.loginsupport (1.0 - 1) <5E2C4AA7-066D-3FDB-B0E1-4CDAF287392C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff651dc000 - 0x7fff65209fff com.apple.contacts.vCard (1.0 - 2326) <38202649-B1F2-3F6D-B2AC-5EC76C9FAB52> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff652ff000 - 0x7fff65332fff libclosured.dylib (519.2.1) <31A6AC03-8F51-367E-9E00-FF0F1AD10F6F> /usr/lib/closure/libclosured.dylib
0x7fff653d1000 - 0x7fff6540aff7 libCRFSuite.dylib (41) <AB2DA745-F22C-30CF-81D4-35DD716463B8> /usr/lib/libCRFSuite.dylib
0x7fff6540b000 - 0x7fff65416fff libChineseTokenizer.dylib (28) <D30A7DB6-058F-3286-9583-60C9EEB77A6E> /usr/lib/libChineseTokenizer.dylib
0x7fff654a8000 - 0x7fff654a9ff3 libDiagnosticMessagesClient.dylib (104) <9712E980-76EE-3A89-AEA6-DF4BAF5C0574> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff654e0000 - 0x7fff656aaff3 libFosl_dynamic.dylib (17.7) <B2476843-7FA7-3E62-B79F-2B15FE557E63> /usr/lib/libFosl_dynamic.dylib
0x7fff656e2000 - 0x7fff656e2fff libOpenScriptingUtil.dylib (174) <203D2C39-61BB-3713-A502-2D17B04A42AC> /usr/lib/libOpenScriptingUtil.dylib
0x7fff6580b000 - 0x7fff6580fffb libScreenReader.dylib (562.1) <107BB2E9-A973-322E-8BDA-5E4DA4061A77> /usr/lib/libScreenReader.dylib
0x7fff65810000 - 0x7fff65811ff3 libSystem.B.dylib (1252) <BBBE6ABC-FD84-30A3-B699-95F1D6EFB334> /usr/lib/libSystem.B.dylib
0x7fff65890000 - 0x7fff65891fff libThaiTokenizer.dylib (2.2) <04AC7CD4-BD9A-3B1D-8CEB-9E2030B6B667> /usr/lib/libThaiTokenizer.dylib
0x7fff658a4000 - 0x7fff658a4fff libapple_crypto.dylib (109.1.6) <1C66C4B7-7E7C-36BC-858E-6661016C971A> /usr/lib/libapple_crypto.dylib
0x7fff658a5000 - 0x7fff658bbff7 libapple_nghttp2.dylib (1.24) <01402BC4-4822-3676-9C80-50D83F816424> /usr/lib/libapple_nghttp2.dylib
0x7fff658bc000 - 0x7fff658e6ff3 libarchive.2.dylib (54) <8FC28DD8-E315-3C3E-95FE-D1D2CBE49888> /usr/lib/libarchive.2.dylib
0x7fff658e7000 - 0x7fff65968fdf libate.dylib (1.13.1) <178ACDAD-DE7E-346C-A613-1CBF7929AC07> /usr/lib/libate.dylib
0x7fff6596c000 - 0x7fff6596cff3 libauto.dylib (187) <A05C7900-F8C7-3E75-8D3F-909B40C19717> /usr/lib/libauto.dylib
0x7fff6596d000 - 0x7fff65a1cffb libboringssl.dylib (109.1.6) <BF41A380-8FD1-3043-BF93-171EBAEE395F> /usr/lib/libboringssl.dylib
0x7fff65a1d000 - 0x7fff65a2dff3 libbsm.0.dylib (39) <770B341F-3BB7-3123-B53C-F2D58868A963> /usr/lib/libbsm.0.dylib
0x7fff65a2e000 - 0x7fff65a3bffb libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
0x7fff65a3c000 - 0x7fff65a92fff libc++.1.dylib (400.9) <FCF5E1F6-2B04-3545-8004-F3AB32FED172> /usr/lib/libc++.1.dylib
0x7fff65a93000 - 0x7fff65ab7ff7 libc++abi.dylib (400.7) <217656D5-BC40-37FF-B322-91CB2AAD4F34> /usr/lib/libc++abi.dylib
0x7fff65ab9000 - 0x7fff65ac9fff libcmph.dylib (6) <A5509EE8-7E00-3224-8814-015B077A3CF5> /usr/lib/libcmph.dylib
0x7fff65aca000 - 0x7fff65ae0fff libcompression.dylib (47) <E64D4416-DFBF-314B-BBB9-BED23C3A251C> /usr/lib/libcompression.dylib
0x7fff65d86000 - 0x7fff65d9eff7 libcoretls.dylib (155) <DFE2454F-2FE3-3B2B-A22B-422947C34C69> /usr/lib/libcoretls.dylib
0x7fff65d9f000 - 0x7fff65da0ffb libcoretls_cfhelpers.dylib (155) <D3F4B882-40C1-3CD4-927B-0E0ED6031D0B> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff65e56000 - 0x7fff65f38ff3 libcrypto.0.9.8.dylib (76) <DC7EA115-9135-3ED9-9A57-3C5588E74592> /usr/lib/libcrypto.0.9.8.dylib
0x7fff65f39000 - 0x7fff660c9fff libcrypto.35.dylib (22) <067CFC21-249D-392D-ADE1-785100BF0F83> /usr/lib/libcrypto.35.dylib
0x7fff66270000 - 0x7fff662c6ff3 libcups.2.dylib (462) <E19FD002-6672-3EE3-B632-34876074270F> /usr/lib/libcups.2.dylib
0x7fff66348000 - 0x7fff6634fff3 libdscsym.dylib (183) <B0DD51C0-0628-38B1-8863-635C4AEBB16E> /usr/lib/libdscsym.dylib
0x7fff66404000 - 0x7fff66404fff libenergytrace.dylib (16) <A92AB8B8-B986-3CE6-980D-D55090FEF387> /usr/lib/libenergytrace.dylib
0x7fff6642c000 - 0x7fff6642dfff libffi.dylib (18.1) <02011073-8CB7-362F-BC52-43B4E83687B0> /usr/lib/libffi.dylib
0x7fff66436000 - 0x7fff6643aff7 libgermantok.dylib (17) <379C5DC6-BEDB-378D-B09C-A63D297EAA6D> /usr/lib/libgermantok.dylib
0x7fff6643b000 - 0x7fff66440ffb libheimdal-asn1.dylib (520) <D968FE68-7770-3AEA-BFEB-3F7F4CB10DDC> /usr/lib/libheimdal-asn1.dylib
0x7fff6646c000 - 0x7fff6655dff7 libiconv.2.dylib (51) <0772997F-4109-38A1-91ED-0F3F16AE99E5> /usr/lib/libiconv.2.dylib
0x7fff6655e000 - 0x7fff66784ffb libicucore.A.dylib (59117.0.1) <EC29683E-E9DE-3100-8F75-D1FEBB82AAB2> /usr/lib/libicucore.A.dylib
0x7fff667d1000 - 0x7fff667d2fff liblangid.dylib (128) <39C39393-0D05-301D-93B2-F224FC4949AA> /usr/lib/liblangid.dylib
0x7fff667d3000 - 0x7fff667ecffb liblzma.5.dylib (10) <3D419A50-961F-37D2-8A01-3DC7AB7B8D18> /usr/lib/liblzma.5.dylib
0x7fff667ed000 - 0x7fff66803ff7 libmarisa.dylib (9) <D6D2D55D-1D2E-3442-B152-B18803C0ABB4> /usr/lib/libmarisa.dylib
0x7fff66804000 - 0x7fff668b3fff libmecab.1.0.0.dylib (779.1) <134BD345-6F0F-32A3-A2BA-AE219D9848E6> /usr/lib/libmecab.1.0.0.dylib
0x7fff668b4000 - 0x7fff66adcfff libmecabra.dylib (779.1) <C1A7BAE5-2E7A-396D-A3A2-00484CAA9B40> /usr/lib/libmecabra.dylib
0x7fff66cb4000 - 0x7fff66d8aff7 libnetwork.dylib (1229.1.5) <6134BC02-EC6F-342F-8FCE-673798505400> /usr/lib/libnetwork.dylib
0x7fff66e00000 - 0x7fff671ee7e7 libobjc.A.dylib (723) <93A92316-DE1E-378C-8891-99720B50D075> /usr/lib/libobjc.A.dylib
0x7fff67201000 - 0x7fff67205fff libpam.2.dylib (22) <7B4D2CE2-1438-387A-9802-5CEEFBF26F86> /usr/lib/libpam.2.dylib
0x7fff67208000 - 0x7fff6723cfff libpcap.A.dylib (79) <D400B242-A56A-39CD-9445-740460F1A62F> /usr/lib/libpcap.A.dylib
0x7fff6723d000 - 0x7fff6727afff libpcre.0.dylib (9) <ABAD6F81-41C0-3AD2-B104-0753A925A205> /usr/lib/libpcre.0.dylib
0x7fff672bc000 - 0x7fff672d8ffb libresolv.9.dylib (65) <E8F3415B-4472-3202-8901-41FD87981DB2> /usr/lib/libresolv.9.dylib
0x7fff67313000 - 0x7fff67325fff libsasl2.2.dylib (211) <D9E281A2-D7BA-32CD-8B96-54972B1D9E66> /usr/lib/libsasl2.2.dylib
0x7fff67326000 - 0x7fff67327ff7 libspindump.dylib (247) <E7A7ECD0-1070-390C-A696-A3305CB9BD87> /usr/lib/libspindump.dylib
0x7fff67328000 - 0x7fff674bdfef libsqlite3.dylib (274.1) <075468C1-75CE-318F-9E9B-F62B6A88E1B3> /usr/lib/libsqlite3.dylib
0x7fff675bf000 - 0x7fff6760dfff libstdc++.6.0.9.dylib (104.1) <92CC5BBD-2FB2-3864-BF6B-B4B1BFF4C1EE> /usr/lib/libstdc++.6.0.9.dylib
0x7fff67640000 - 0x7fff67675fff libtidy.A.dylib (15.18.1) <3E33A53A-53AB-3FD5-BBAB-DFA6A3A90132> /usr/lib/libtidy.A.dylib
0x7fff6768d000 - 0x7fff676c6ffb libusrtcp.dylib (1229.1.5) <F3338E88-885C-3203-9D5A-5CA51CEBE567> /usr/lib/libusrtcp.dylib
0x7fff676c7000 - 0x7fff676caffb libutil.dylib (51) <58C59F00-031B-3798-B697-A8A4C58E70AA> /usr/lib/libutil.dylib
0x7fff676cb000 - 0x7fff676d8fff libxar.1.dylib (400) <0316128D-3B47-3052-995D-97B4FE5491DC> /usr/lib/libxar.1.dylib
0x7fff676dc000 - 0x7fff677c3fff libxml2.2.dylib (31.7) <49544596-BCF8-3765-8DC5-DB1A9A90EF92> /usr/lib/libxml2.2.dylib
0x7fff677c4000 - 0x7fff677ecfff libxslt.1.dylib (15.10) <66682AF6-C2D5-374C-901F-25A3E72814DC> /usr/lib/libxslt.1.dylib
0x7fff677ed000 - 0x7fff677ffffb libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
0x7fff6789c000 - 0x7fff678a0ff7 libcache.dylib (80) <354F3B7D-404E-3398-9EBF-65CA2CE65211> /usr/lib/system/libcache.dylib
0x7fff678a1000 - 0x7fff678abff3 libcommonCrypto.dylib (60118.1.1) <6C502A55-3B54-3B48-BA7B-FA39F56C0B1E> /usr/lib/system/libcommonCrypto.dylib
0x7fff678ac000 - 0x7fff678b3fff libcompiler_rt.dylib (62) <4487CFBA-A5D7-3282-9E6B-94CAD7BE507E> /usr/lib/system/libcompiler_rt.dylib
0x7fff678b4000 - 0x7fff678bcfff libcopyfile.dylib (146) <7E4BD264-5617-339B-AC73-E8D07EF2C51D> /usr/lib/system/libcopyfile.dylib
0x7fff678bd000 - 0x7fff67941ff7 libcorecrypto.dylib (562) <7974762C-DEF7-3056-9856-9821C27846DB> /usr/lib/system/libcorecrypto.dylib
0x7fff679c8000 - 0x7fff67a01ff7 libdispatch.dylib (913.1.6) <0DD78497-6A2A-350A-99EF-15BF41EA07DD> /usr/lib/system/libdispatch.dylib
0x7fff67a02000 - 0x7fff67a1fff7 libdyld.dylib (519.2.1) <2597D818-42D2-3375-BD9D-451D5942A6BA> /usr/lib/system/libdyld.dylib
0x7fff67a20000 - 0x7fff67a20ffb libkeymgr.dylib (28) <6D84A96F-C65B-38EC-BDB5-21FD2C97E7B2> /usr/lib/system/libkeymgr.dylib
0x7fff67a21000 - 0x7fff67a2dff3 libkxld.dylib (4570.1.46) <AE8CE609-ECB8-3D2E-8823-C103A56064DF> /usr/lib/system/libkxld.dylib
0x7fff67a2e000 - 0x7fff67a2eff7 liblaunch.dylib (1205.1.10) <5AD77A68-BB4D-33AA-AA4F-DF51D0972FD9> /usr/lib/system/liblaunch.dylib
0x7fff67a2f000 - 0x7fff67a33ffb libmacho.dylib (900.0.1) <756F2553-07B6-3B42-ACEA-2F0F1A5E8D0F> /usr/lib/system/libmacho.dylib
0x7fff67a34000 - 0x7fff67a36ff3 libquarantine.dylib (86) <6AC8773F-3817-3D82-99C2-01BABB9C3CBB> /usr/lib/system/libquarantine.dylib
0x7fff67a37000 - 0x7fff67a38ff3 libremovefile.dylib (45) <912FA211-DD8C-3C92-8424-21B89F8B10FD> /usr/lib/system/libremovefile.dylib
0x7fff67a39000 - 0x7fff67a50fff libsystem_asl.dylib (356.1.1) <94972913-9DF0-3C78-847C-43E58919E3DA> /usr/lib/system/libsystem_asl.dylib
0x7fff67a51000 - 0x7fff67a51fff libsystem_blocks.dylib (67) <F2493BB5-B1C6-3C4D-9F1F-1B402E0F1DB7> /usr/lib/system/libsystem_blocks.dylib
0x7fff67a52000 - 0x7fff67adbfff libsystem_c.dylib (1244.1.7) <2D4C21C0-9938-3552-8DC1-2C1CFAA10D38> /usr/lib/system/libsystem_c.dylib
0x7fff67adc000 - 0x7fff67adfffb libsystem_configuration.dylib (963) <D7EFEAE6-22A0-348E-BBBE-44FFD41934FA> /usr/lib/system/libsystem_configuration.dylib
0x7fff67ae0000 - 0x7fff67ae3ffb libsystem_coreservices.dylib (51) <21A488D0-2D07-344E-8631-CC8B2A246F35> /usr/lib/system/libsystem_coreservices.dylib
0x7fff67ae4000 - 0x7fff67ae5fff libsystem_darwin.dylib (1244.1.7) <552C05CA-D151-3F93-B570-413340BDA9C7> /usr/lib/system/libsystem_darwin.dylib
0x7fff67ae6000 - 0x7fff67aecff7 libsystem_dnssd.dylib (878.1.1) <6E28973E-A258-36F6-ACFB-259ED5885C7A> /usr/lib/system/libsystem_dnssd.dylib
0x7fff67aed000 - 0x7fff67b36ff7 libsystem_info.dylib (517) <483BE95B-62EB-3663-ACB3-9915A40C70F5> /usr/lib/system/libsystem_info.dylib
0x7fff67b37000 - 0x7fff67b5cff7 libsystem_kernel.dylib (4570.1.46) <71BA15CB-3056-3CBD-A5F5-EE61566EEA0C> /usr/lib/system/libsystem_kernel.dylib
0x7fff67b5d000 - 0x7fff67ba8fcb libsystem_m.dylib (3146) <ABB1B85F-9FFE-31B8-AD4F-E39A30794A93> /usr/lib/system/libsystem_m.dylib
0x7fff67ba9000 - 0x7fff67bc8fff libsystem_malloc.dylib (140.1.1) <9F0745FF-B92F-330D-8812-BB74001D1D33> /usr/lib/system/libsystem_malloc.dylib
0x7fff67bc9000 - 0x7fff67c6cff3 libsystem_network.dylib (1229.1.5) <A51EB0A4-9AA5-3F84-8E25-DD8EABE0F97E> /usr/lib/system/libsystem_network.dylib
0x7fff67c6d000 - 0x7fff67c77ffb libsystem_networkextension.dylib (767.1.4) <E842569D-00BA-3DE7-AD5A-9EF33422CF3E> /usr/lib/system/libsystem_networkextension.dylib
0x7fff67c78000 - 0x7fff67c81ff3 libsystem_notify.dylib (172) <98EA3D62-7C86-30DE-8261-D020D2F1EFF3> /usr/lib/system/libsystem_notify.dylib
0x7fff67c82000 - 0x7fff67c89ff7 libsystem_platform.dylib (161) <9F5A67F7-BC65-300F-BD74-07E7732D6372> /usr/lib/system/libsystem_platform.dylib
0x7fff67c8a000 - 0x7fff67c95ff7 libsystem_pthread.dylib (301.1.6) <6D0B0110-2B44-3D3C-B672-BD08FE46378A> /usr/lib/system/libsystem_pthread.dylib
0x7fff67c96000 - 0x7fff67c99ffb libsystem_sandbox.dylib (765.1.8) <EC909728-0365-3710-B00B-0BCFCE03DC71> /usr/lib/system/libsystem_sandbox.dylib
0x7fff67c9a000 - 0x7fff67c9bff3 libsystem_secinit.dylib (30) <F06ADB8F-9E94-34A7-B3C9-2C22FDD14BAD> /usr/lib/system/libsystem_secinit.dylib
0x7fff67c9c000 - 0x7fff67ca3ff7 libsystem_symptoms.dylib (820.1.4) <BF0566B2-9475-3B5C-8641-7910F313BA3C> /usr/lib/system/libsystem_symptoms.dylib
0x7fff67ca4000 - 0x7fff67cb7ff7 libsystem_trace.dylib (829.1.2) <10955EBB-1AC8-3085-9A2D-F3088CA2DF71> /usr/lib/system/libsystem_trace.dylib
0x7fff67cb9000 - 0x7fff67cbeff7 libunwind.dylib (35.3) <6D4FCD49-D2A9-3233-95C7-A7635CE265F2> /usr/lib/system/libunwind.dylib
0x7fff67cbf000 - 0x7fff67ceaff7 libxpc.dylib (1205.1.10) <E7C5DB12-6D0E-3D1E-A743-F750DF112F5F> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1485
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=585.6M resident=0K(0%) swapped_out_or_unallocated=585.6M(100%)
Writable regions: Total=540.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=540.8M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.4M 5
ATS (font support) (reserved) 8K 3 reserved VM address space (unallocated)
Accelerate framework 256K 3
Activity Tracing 256K 2
CG backing stores 4396K 7
CG image 1056K 28
CoreAnimation 288K 17
CoreGraphics 8K 2
CoreImage 20K 6
CoreUI image data 2180K 29
CoreUI image file 612K 9
Foundation 20K 3
Image IO 68K 3
Kernel Alloc Once 8K 2
MALLOC 361.5M 379
MALLOC guard page 96K 22
Memory Tag 240 276.8M 297
Memory Tag 242 12K 2
SQLite page cache 64K 2
STACK GUARD 56.1M 30
Stack 23.2M 31
VM_ALLOCATE 17.1M 66
__DATA 57.9M 407
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__LINKEDIT 191.8M 52
__TEXT 393.8M 380
__UNICODE 556K 2
libnetwork 128K 3
mapped file 255.0M 70
shared memory 2968K 25
TOTAL 1.6G 1860
TOTAL, minus reserved VM space 1.6G 1860
Hi Adamg,
I apologize for the inconvenience caused. As I understand from the description above, the Acrobat Pro DC is crashing in Mac OS 10.13, Is that correct?
Please try the troubleshooting steps from the following KB doc: Troubleshoot Mac OS 10.x system errors, freezes | Adobe software Link: https://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-freezes-mac.html
You can also try to reset the Acrobat Preferences, to reset preferences refer to How to reset Preference settings in Acrobat. Link: https://forums.adobe.com/thread/1595848
Hope this helps, and keep us posted with the results.
Anand Sri.
I have tried the troubleshooting page and also tried to reset the preferences. Neither one of the suggestions solutions worked. Also, yes, the Mac OS I'm under is 10.13, just like I stated in the first message.
Hi Adamg,
If the issue still persists, please enable the root account, and check with Acrobat. Keep us posted wit with results.
Anand Sri.
Is there a way i can share a video of what is going on so you can see exactly what is happening? Now it's to a point where if I click out of acrobat to open a new file or even just clicking on the desktop will crash the whole program.
Hi Adamg,
Sorry for the delay in response to your query. You can share the screenshot of the issue through https://forums.adobe.com/docs/DOC-7161
Please enable the root account and check with the Acrobat.
Keep us posted with the results.
Anand Sri.
I activated the root account and adobe seems to be working under that account. I've uploaded a video screenshot of what is going on. It shows how it crashes when I click out of the program.
Also, I should note that the single file .pdf's don't crash. It's only when I open a portfolio and open one of the documents in that file.
Hi Adamg,
If it's working in the root account, then it seems to be a user profile issue of your operating system. You may try to create a test user profile and work on Acrobat.
I will look into a solution asap and will follow up with you.
Thanks for your time and patience.
Anand Sri.
Any update to this? I have exactly the same issue...
Nope, I tried wiping my hd and it still has an issue. I guess acrobat only works if it's the only program on the mac and nothing else. I also haven't heard back from AnandSri since that last message he sent so i'm still waiting on that too.
Hello Adamg,
Sorry for the delay in response to your query and apologize for the inconvenience caused as I was occupied with another project.
As I have shared all the possible steps to resolve the issue, but as per your description the issue is not fixed.
Please help me with your contact details i.e. Phone number, Time Zone, the Best time for a callback , Email address in a Private message, The specified item was not found. Link: https://forums.adobe.com/thread/1184148
So that I can arrange a call back for you from the product team.
NOTE: Please don't share any personal information on the forum page.
Anand Sri.
Hello Illibuck,
Anand Sri.
It turns out that the problem I was having was related to the dropbox app I had on the mac. They said it was a known issue and they are working on getting it resolved. Once I closed my dropbox app, acrobat started working fine.
Hello Adamg,
Great! Good to hear that you are able to use the Acrobat, and thank you so much for sharing the workaround related to the Dropbox, give us a shout if you need any assistance with Acrobat/Reader in future.
Anand Sri.
