• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Export PPT - PDF Color Shift
Community Beginner ,
May 23, 2018 May 23, 2018
I've tried setting all of the Advanced options (High Quality Print, RGB color...) that I found from documents on here, but my colors are still changing!
And does it matter how it is being generated
  • File > Save As Adobe PDF
  • File > Print > Choose Adobe PDF as printer
  • Create PDF from the Acrobat Toolbar in Powerpoint
TOPICS
Create PDFs
Views
7.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
May 25, 2018 May 25, 2018
Hi Rosemarya,
As per the issue description mentioned above, you are facing issue when trying to convert ppt file to a pdf, is that correct?
Could you try creating pdf using a web browser at this link: https://cloud.acrobat.com/convertpdf and check if the resultant file looks okay.
Also, check if an update is available for Acrobat using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again. You may also download updates from here: Adobe software and product updates
Would it be possible if you can share the ppt file you are working with to replicate the issue at our end? To share the file here in the forums: How to share a file using Adobe Document Cloud
Shivam
Votes
Translate
Translate
Report
Report
Shivam,
When I try to convert a ppt to pdf on the cloud I am unable to. I am logged into my account. I only have a Subscribe Now option.
FYI I don’t have a “Check for Updates” option under the help menu.  Maybe this is because my version is so old.
I was running version 2015.016.20039. Here is what I saw.
I updated to 2018.01120040 from the web link you provided.
Finally, the problem is still happening. I sent the .ppt and a generated PDF.
https://files.acrobat.com/a/preview/efbe6d91-aefe-4207-ab53-60006a973e56
https://files.acrobat.com/a/preview/da171f04-2032-48f0-94e0-089020ce12c5
Does is matter how I generate the PDF?
I have several options and I never know if there is a difference between them
File > Print > Adobe PDF
File > Save As > Choose .pdf
File > Save as Adobe PDF
Create PDF from the ACROBAT toolbar
Rosemary Astheimer
[personal info removed by moderator]
Votes
Translate
Translate
Report
Report
  • When I try to convert a ppt to pdf on the cloud I am unable to. I am logged into my account. I only have a Subscribe Now option.
  • FYI I don’t have a “Check for Updates” option under the help menu.  Maybe this is because my version is so old.
    • I was running version 2015.016.20039. Here is what I saw.
    • I updated to 2018.01120040 from the web link you provided.
  • Does is matter how I generate the PDF? I have several options and I never know if there is a difference between them
    • File > Print > Adobe PDF
    • File > Save As > Choose .pdf
    • File > Save as Adobe PDF
    • Create PDF from the ACROBAT toolbar
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jun 06, 2018 Jun 06, 2018
Hi Rosemarya,
Thanks for sharing the files. We tried replicating the issue at our end using the three options you mentioned above but the issue was not reproducible.
Please find below the screenshots:
Try resetting preferences for Acrobat using the steps given in the following link, reboot the machine and check if that helps:
How to reset Acrobat Preference settings to default.
Shivam
Votes
Translate
Translate
Report
Report
LATEST
Unfortunately this didn't do the trick either.
I am going to uninstall and reinstall entirely to see if that corrects it.
Votes
Translate
Translate
Report
Report
